Run a script from tool palette
Crass
Crass
Hello I've create a simple script to clean consultant drawings and I wanted to create a button on a tool palette to run it. What am I doing wrong here? I assume there is some syntax error. Or is there a better way to do this? Thanks!
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Moshe-A
@Crass hi,
in menu macro terms '\' is treated as pause, replace each '\' with '/'
Moshe
Sea-Haven
Have you thought about adding the file path to "support paths & trusted paths" then can just call the script by name, no need for directory path.
^c^cScript Cleanconsultantdwg
Note if you have spaces in the script name enclose with quotes "Clean consultant dwg" etc
Crass
Doh! Thanks @Moshe-A. Appreciate it! Obviously a n00b error. I don't have a code / script-writing background so just trying to learn by doing it. Were there any references or tutorials you sounds helpful as you were getting started.
AutoCAD 2018/2021
Crass
Thanks @Sea-Haven this is a great idea. I will try it now.
AutoCAD 2018/2021
