Run a lisp (not load) when a drawing opens
yan_ken
Message 1 of 23
yan_ken
HI Folks,
I want to run a run or execute a lisp routine when a drawing is opened. I don't mean loading lisp file, which is already in the APPLOAD startup suite.
How can I run a lisp on every drawing I open?
Thank you,
Ken
Replies (22)
Message 21 of 23
hi kent
i will try and then i say it will happen or not. thank you so much
best regards
hussain
Message 22 of 23
JamesMaeding
This is a communication problem, not an Autocad problem.
To the OP, you might contact autodesk for help on this, state the language you prefer.
Not picking on anyone, but 6 posts on loading a lisp with not much meaningful feedback is futile.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 23 of 23
DGRL
Hi @yan_ken
At the end of the lisp just place (c:yourcommand) and it should run automaticly when loaded
best regards,
If this was of any help please kudo and/or Accept as Solution
Kind Regards
