Hello Friends
I am looking for a routine to find / see (by drawing colored circle on the current layer) Blocks with the Same XY Scale
and others Scales ...
And I don't find it !
Green Circle if the Blocks has the same positive X & Y Scale, for example: X = N & Y = N
Blue Circle if X = N & Y = -N
Magenta Circle if X = -N & Y = N
Red Circle if X = -N & Y = -N
Cyan when X & Y are differents (in Absolute value)
Please look at the joined DWG ...
I see the following routine :
- Check that we are into the WCS
- Ask for the circle radius
- Ask for the selection (Standard ACAD selection) & Retains ONLY Blocks (INSERT) - No XREF please
- Draw Circle with the right color at each XYZ block insert point
I hope my wish is CLEAR !?
It's to detect usage of MIRROR on Blocks and Updates on the XY Scale ...
Thanks in advance, Regards, Patrice
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
