Routine that selects lines of the same length
isaacV7RNV
isaacV7RNV
I know qsel does this but is there a faster version?
I dont want to have to copy the line length and go into qsel everytime.
Anyone have a routine like this or similar i can edit?
paullimapa
how's about this code on this old thread:
filtering lines by length - Autodesk Community - Community Archive - Read Only
Paul Li
IT Specialist
@The Office
isaacV7RNV
Ive seen that one but its also a bit tedious. These lines have multiple decimal places so itd be handy to just select the line I want and it selects the rest of them that are the same.
I might try and work on this code then if theres no other solutions
paullimapa
should be pretty straight forward to do a selection of a line object and then use the part of the code that's already given to the get the length of the line selected:
(while (not ent)
 (setq ent (ssget "_+.:E:S" '(( 0 . "LINE")))) ; select line
; get length of selected line
(setq ent (ssname ent 0)
      STPT (cdr (assoc 10 (entget ENT))) ; start point of selected line
      ENPT (cdr (assoc 11 (entget ENT))) ; end point of selected line
      LEN (distance STPT ENPT) ; length of selected line
) ;end setq
Paul Li
IT Specialist
@The Office
hak_vz
(defun c:sbl ( /  eo do ss  ssl i)
	(setq ss nil)
	(princ "\nSelect line to collect required length!")
	(while (null ss)(setq ss (ssget "+.:E:S" '(( 0 . "LINE")))))
	(setq
		eo (vlax-ename->vla-object (ssname ss 0))
		d (vlax-get eo 'length)
	(setq ss (ssget "X" '((0 . "LINE"))) ssl (ssadd) i -1)
	(while (< (setq i (1+ i))(sslength ss))
		(setq
			eo (vlax-ename->vla-object (ssname ss i))
			do (vlax-get eo 'length)
		(if (<= (abs(- do d)) 1e-10)(setq ssl (ssadd (ssname ss i) ssl)))
	 (sssetfirst nil ssl)
	 (princ)
Miljenko Hatlak
Kent1Cooper
Another similar way [similar in finding all Lines and comparing the length of each to that of the reference Line, and leaving you with the qualifying ones selected/gripped/highlighted], but that involves no extraction of Line endpoints or VLA object conversion to get the reference or comparison lengths, nor multiple selection sets:
(defun C:SLSL  (/ lsel reflen n lin ss); = Select Lines of Same Length
  (if
    (and
      (setq lsel (entsel "\nSelect Line of reference length: "))
      (member '(0 . "LINE") (entget (car lsel)))
    ); and
    (progn ; then
      (setq reflen (getpropertyvalue (car lsel) "Length"))
      (repeat (setq n (sslength (setq ss (ssget "X" '((0 . "LINE")))))); then
        (setq lin (ssname ss (setq n (1- n))))
        (if (not (equal (getpropertyvalue lin "Length") reflen 1e-2))
          (ssdel lin ss); remove
        ); if
      ); repeat
      (sssetfirst nil ss)
    ); progn
    (prompt "\nNo LINE selected."); else
  ); if
  (prin1)
[Yes, I know selection can be limited to a single Line in (ssget), but you can't escape its "Select objects: " prompt always in the plural, so I don't like to use it when going for a single thing.  I go for (entsel) in which you can specify your own prompt within the selection function itself.]
That defines "same length" as being within 1/100 of a drawing unit.  Adjust the 1e-2 for a different precision, or the routine could be made to ask for a precision, and if you like, remember it for subsequent use.
Kent Cooper, AIA
