Rounding up selected values to user input standard values (Please see attachment
Message 1 of 24
Hi Experts,
I need a favor, to update the selected texts to standard values mentioned by user.
Please have a look on attached dwg.
Advanced Thank you all.
Accepted solutions (3)
Replies (23)
Message 21 of 24
pbejse
@john.uhden wrote:
Instead of that myopic RealorInt function, I think it's simpler...
Command: (type 3) INT
Command: (type 3.0) REAL
That also is true, but regardless of what method was used, you still need the output of rtos precision argument.
type
(if (Eq (type n) 'INT) 0 2)
rem
(if (zerop (rem n 1)) 0 2)
I  usualy create a sub that i re-use and include on my toolbox whenever needed. 🙂
Message 22 of 24
john.uhden
Correct. I was just pointing out that a rem of zero does not necessarily
mean an integer.
John F. Uhden
Message 23 of 24
pbejse
mean an integer.
Correct thumbsup.gif,
Guess i'm more into using math for evaluation since i switch from one program language to another.
Hoepfully the OP would not include the trailing zeros on the source file. 20.00
But you right about zero.
Taking John's advice.
(defun c:RoundUpFromRange ( / _L2S RealorInt range rangeSource opf a i s ent v)
;;		pBe May 2020		;;
(defun _L2S (s a)
  ((lambda (v)
     (setq s (vl-string-right-trim v s)
	   s (vl-string-Left-trim v s)))
    (strcat "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz" a))
(setq RealorInt (lambda  (n)
(if (and
	(setq range nil
	      rs (getfiled "Select Source file"
				    (if	rs (vl-filename-directory rs)
				      (getvar 'dwgprefix)) "txt" 16)
	(setq range
	       (progn
		 (setq opf (open rs "r"))
		 (while	(setq a (read-line opf))
		   (if (numberp (setq a (Read a)))
		   (setq range (cons a range)))
		 (close opf)
		 (reverse range))
	(princ "\nActual values, ")
	(setq s (ssget "_:L" '((0 . "TEXT"))))
 (repeat (setq i (sslength s))
   	(if
	  (setq	e (ssname s (setq i (1- i)))
		v   (atof (_L2S (getpropertyvalue e "TextString") ""))
		v   (Vl-some '(lambda (n m)
				(cond
				  ((<= v n) n)
				  ((<= n v m) m)
			      ) range (Cdr range)
	  (setpropertyvalue e "TextString" (rtos v 2 (RealorInt v))))
  (princ)
Message 24 of 24
Sea-Haven
A front end. The options are dynamic limited by screen size row spacing reduces for more selections.
