Rotate to set object at angle - using 'getangle' works bad
Here I have something very strange for me.
Do you remember my lisps RT2SETNG and RT2SETPOI?
They are now called RTREFNG and RTREFPOI.
; Lisps are here: ; http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rotate-selected-object-to-position-given-1-by-value-or-2-by-two/td-p/5476226 ; On ground of: ; http://www.ellenfinkelstein.com/acadblog/rotate-one-object-to-match-another/ ; ROTATE, Enter --> BasePoint --> Reference --> Angle ; Ustawiasz, by wybrany obiekt leżał pod kątem wskazanym za pomocą wartośc podanej ręcznie ; RT2SETNG = RoTate TO the SETted aNGle (position) ; RTREFNG = RoTate REFerence aNGle (DEFUN C:RTREFNG () (setq zbior (ssget)) (setq pt1 (getpoint "\nClick on a point on the rotated Object (it will be a BasePoint): ")) (setq pt2 (getpoint "\nClick on the other point on the rotated Object: ")) ; These two points (endpt1, endpt2) determine a straight line which Angle (position) will be set to value you type (setq angle (getreal "\nSet angle (position of the selected object after Rotating): ")) (command "_ROTATE" ;Select objects: zbior "" ;Specify base point: pt1 ;Specify rotation angle or [Copy/Reference] <0>: "R" ; Reference ;Specify the reference angle pt1 pt2 ;Specify the new angle or [Points] <0>: angle ) ) ;Command: ROTATE nil ; ;Select objects: 1 found ; ;Select objects: ; Wybieram Linię/ Obiekt ;Specify base point: ; Wskazuję Base Point - jeden z Endpointów Linii ;Specify rotation angle or [Copy/Reference] <11>: r ; Reference, Enter ;Specify the reference angle <23>: ; 1x LPMem na punkt, który jest BasePoint'em ; Specify second point: ; 1x LPMem na Punkt leżący na prostej należącej do Obiektu, na którym leży także BasePoint ;Specify the new angle or [Points] <34>: 56 ; I type new value for Angle, Enter ; The Line has such position, that it's Angle is equal to 56 ;------- ; ŚWIETNY LISP ; Jak ALIGN, tylko że robisz sam obrót, bez przyciągania jednego obiektu do drugiego. ; Ustawiasz, by wybrany obiekt leżał pod kątem wskazanym za pomocą dwóch punktów. ; GREAT LISP ; Like ALIGN. nut you order only ROTATE, without snap the two Objects to eachother. ;You set the chosen Object to lie at the Angle definied by picking two Points. ; See also lisps: SNAPANG ; Zrobię jeszcze drugą taką komendę. ; Ona będzie wydawać polecenia w takiej kolejności jak ALIGN: ; Pick first source point. Pick first destination point. Pick second source point. Pick second destination point. ; I made one more lisp, very similar to RTREFPOI, but it will be ; give orders in the same order as ALIGN command: ; Pick first source point. Pick first destination point. Pick second source point. Pick second destination point. ; So this lisp will be called RTREFPOIALIGN ; ROTATE, Enter --> BasePoint --> Reference --> Points ; RTREFPOI = RoTate REFerence POInts ; AGG - bo jest jak AliGn ; RT2SETPOI = RoTate TO the SETted angle (position) - which is setted with two POInts (DEFUN C:RTREFPOI () (setq zbior (ssget)) (setq ptA1 (getpoint "\nClick on a point on the rotated Object (it will be a BasePoint): ")) (setq ptA2 (getpoint "\nClick on the other point on the rotated Object: ")) ; These two points (ptA1, ptA2) determine a straight line which Angle (position) will be set to value you type (setq ptB1 (getpoint "\nDetermine position of the selected Object after Rotate.\nClick on a point you refer to: ")) ; "\nDetermine Angle (position) of the selected Object, which will it have after Rotate. (setq ptB2 (getpoint "\nClick on the other point you refer to: ")) (command "_ROTATE" ;Select objects: zbior "" ;Specify base point: ptA1 ;Specify rotation angle or [Copy/Reference] <0>: "R" ; Reference ;Specify the reference angle ptA1 ptA2 ;Specify the new angle or [Points] <0>: "P" ; Points ;Specify first point: ptB1 ;Specify second point: ptB2 ) ) ;------ ; # THE BEST ! ; ALIGN, bo wydaje polecenia w takiej kolejności, co ALIGN ; ALIGN, because it gives orders in the same order as the ALIGN command (DEFUN C:RTREFPOIALIGN () (setq zbior (ssget)) (setq ptA1 (getpoint "\nPick first source point: ")) (setq ptB1 (getpoint "\nPick first destination point: ")) (setq ptA2 (getpoint "\nPick second source point: ")) (setq ptB2 (getpoint "\nPick second destiation point: ")) (command "_ROTATE" ;Select objects: zbior "" ;Specify base point: ptA1 ;Specify rotation angle or [Copy/Reference] <0>: "R" ; Reference ;Specify the reference angle ptA1 ptA2 ;Specify the new angle or [Points] <0>: "P" ; Points ;Specify first point: ptB1 ;Specify second point: ptB2 ) )
In one of the topics I created somebody wrote to me that I wrote in lisp
(setq Angle (getreal "\nType value..."))
and that is maybe not so bad, but certainly not properly.
That is because I should write 'getangle' instead of 'getreal' - with 'getangle' the user can as well type value by keyboard as well pick two points.
I remember this today and I wanted to create lisp such as RTREFNG and RTREFPOI in one, and that's thanks to using 'getangle'.
So I used 'getangle':
; Nie działa jak należy ; W wyniku obrotu linia nie znajdzie się ; pod wybraym kątem. ; It doesn't works like I expected. ; In result of rotate, the chosen Line will be ; not positioned at definied angle. ; RTREFNG oraz RTREFPOI w jednym ; możesz zdefiniować pozycję wybranego odcinka Obiektu po obrocie ; i przez podanie wartości z klawiatury, i przez kliknięcie w dwa punkty ; It is RTREFNG and RTREFPOI in one ; You can define position of chosen Segment from the Object, which will it have after rotate. ; You can define its position as well by typing the value by keyboard, ; as well by picking two Points ;RTREFNGPOI = RoTate REFerence aNGle POInts ;RTREFAG = RoTate REFerence AliGn (DEFUN C:RTREFAG () (setq zbior (ssget)) (setq pt1 (getpoint "\nClick on a point on the rotated Object (it will be a BasePoint): ")) (setq pt2 (getpoint "\nClick on the other point on the rotated Object: ")) ; These two points (endpt1, endpt2) determine a straight line which Angle (position) will be set to value you type (setq ang (getangle "\nSet POSITION of the selected object after Rotating - TYPE value OR PICK two Points: ")) (command "_ROTATE" ;Select objects: zbior "" ;Specify base point: pt1 ;Specify rotation angle or [Copy/Reference] <0>: "R" ; Reference ;Specify the reference angle pt1 pt2 ;Specify the new angle or [Points] <0>: ang ) )
But it doesn't work... All I described in code.
It works on the same rule as RTREFNG and RTREFPOI, which both work properly. Where are differences from?
