Rotate Text
Rotate Text
Philip-John
Message 1 of 9
Rotate Text
Philip-John
I have got the following lisp to display area inside the box. But the text is in 0°. Can somebody help me to modify the lisp to display text in various angles. i.e 90°, 180°, 270° ?
(vl-load-com)
(defun c:TXTAREA (/ area ent flag lst obj pt tmpH)
(if (or (not *Hscl*) (/= (type *Hscl*) 'REAL))
(setq *Hscl* (getvar 'TEXTSIZE))
(initget 6)
(setq tmpH (getreal (strcat "\nSpecify Text Height: <" (rtos *Hscl*) ">: ")))
(if (/= tmpH nil)
(setq *Hscl* tmpH)
(while (null flag)
(cond ((setq pt (getpoint "\nSpecify internal point <exit>: "))
(if (and (setq lst (entlast))
(vl-cmdf "_.-boundary" pt "")
(setq ent (entlast))
(not (eq lst ent))
(progn
(setq obj (vlax-ename->vla-object ent)
area (vla-get-area obj)
(entmake (list
'(0 . "TEXT")
(cons 10 (trans pt 1 0))
(cons 40 *Hscl*)
(cons 1 (strcat (rtos area 2 2) " m2"))
(cons 50 (angle '(0.0 0.0) (getvar 'UCSXDIR)))
(T
(setq flag T)
(princ)
Accepted solutions (3)
Replies (8)
Message 2 of 9
pbejse
Via user prompt before you place the text?
Message 3 of 9
hak_vz
Try this
(vl-load-com)
(initget 6)
(if (/= tmpH nil)
(setq *Hscl* tmpH)
(while (null flag)
(not (eq lst ent))
(progn
(setvar 'TEXTEVAL 1)
(setvar 'TEXTEVAL 0)
(entmake (list
'(0 . "TEXT")
(cons 40 *Hscl*)
(cons 1 (strcat (rtos area 2 2) " m\U+00B2"))
(cons 50 (getangle "\nEnter or pick text angle >" pt))
(T
(setq flag T)
(princ)
Miljenko Hatlak
Message 4 of 9
Philip-John
Message 5 of 9
Philip-John
Can you make it in both ways?
Message 6 of 9
Philip-John
Thanks..
Can you make it for fixed angle that I will set in lisp itself?
Message 7 of 9
hak_vz
This line defines angle
Instead (getangle....)) enter angle in radians an that's it.
(cons 50 0.7......)
You can have multiple versions of this function i.e txtarea45 txtare90
Miljenko Hatlak
Message 8 of 9
pbejse
Sure
(defun c:TXTAREA (/ area ent flag _Text lst obj pt tmpH gr data ct)
(defun _Text (pt  / obj area text)
	   (not (eq lst ent))
    (progn
		area (vla-get-area obj))
      (entmakex
			(list
			  '(0 . "TEXT")
			  (cons 40 *Hscl*)
			  (cons 50 Txrot)
  (initget 6)
  (setq	tmpH (getreal
  (if (/= tmpH nil)
    (setq *Hscl* tmpH)
(setq Txrot (cond
    ((getangle
        (strcat "\nEnter rotation <" (angtos (setq Txrot
              (cond ( Txrot ) ( (angle '(0.0 0.0) (getvar 'UCSXDIR)) ))
            ) 0 2
    ( Txrot )
(if (setq pt (getpoint (strcat "\nSpecify internal point <exit>: ")))
	(progn
	  (setq ct  (_Text pt))
	     (princ "\nSpecify Next Point [Rotate]:<exit> ")
	      (while
	        (progn
	          (setq gr (grread t 15 0) code (car gr)
	               data (cadr gr)
	          (cond
	            ((= 5 code)  data)
	              (and (= 2 code)(member  data '( 114 82)))
			(Vlax-put (Setq ev (vlax-ename->vla-object ct)) 'Rotation
				  (setq Txrot (+ (vlax-get ev 'Rotation) (/ pi 2.0))) )
	              t
	            ((= 3 code)
		     (setq ct (_Text data))
  (princ)
Command: TXTAREA
Specify Text Height: <0.20>: .2
Enter rotation <0.00>: Enter
Command: TXTAREA
Specify Text Height: <0.20>: .Enter
Enter rotation <0.00>: 45
Specify Next Point [Rotate]:<exit> Pressed "R"  and the text will rotate 90 degrees counter clockwise
HTH
Message 9 of 9
Philip-John
Thanks a lot pbejse..
Your lisp is wonderful..
