Revolve Mesh Command Help
Hello
I wrote a lisp which Revolves 3DPolyline around a line and creates 3DMesh Object.
But sometimes it puts some points out of their coordinates.
Coul you advise please.
(defun c:revmesh(/ Pl-Type Pl-Name Li-Type Li-Name Li-Opt)
(setq Pl-Type nil);ТИП Полилиния
(while (/= Pl-Type "POLYLINE")
(setq Pl-Name (car (entsel "\nSelect a Polyline: ")))
(setq Pl-Type (cdr(nth 1 (entget Pl-Name))))
(cond
((/= Pl-Type "POLYLINE")(print "Select 3D Polyline Pl-ease"))
(setq Li-Type nil)
(while (/= Li-Type "LINE")
(setq Li-Name (car (entsel "\nSelect a Line: ")))
(setq Li-Type (cdr(nth 1 (entget Li-Name))))
(cond
((/= Li-Type "LINE")(print "Select a Line Please"))
(setq Li-Opt (entget Li-Name))
(command "ucs" "za" (cdr(assoc 10 Li-Opt)) (cdr(assoc 11 Li-Opt)))
(setq Coord-List '());Список координат
(repeat 12
(setq Coord-List (cons (vlax-safearray->list (vlax-variant-value (vla-get-coordinates (vlax-ename->vla-object PL-Name)))) Coord-List))
(command "rotate" Pl-Name "" "0,0,0" "30")
(setq New-List nil)
(setq numb 0)
(setq ppp 0)
(setq New-New-List nil)
(while (/= (nth ppp Coord-List) nil)
(setq New-List (append (nth ppp Coord-List) New-List))
(setq ppp (+ ppp 1))
(while (/= (nth numb New-List) nil)
(setq New-New-List(cons (strcat(rtos(nth numb New-List))","(rtos(nth (+ numb 1) New-List))","(rtos(nth (+ numb 2) New-List)))New-New-List))
(setq numb (+ 3 numb))
;(setq Coord-List (mapcar' vl-princ-to-string Coord-List))
;;(setq Coord-List (mapcar'(lambda(a)(vl-string-trim "()" a))Coord-List))
(setq List-Length (length New-New-List))
(setq List-Length-12 (/ List-Length 12))
(command "_3dmesh" "12" List-Length-12
;(command "point"
(mapcar 'command New-New-List)
(command "pedit" "last" "nclose" "mclose" "exit")
marko_ribar
Just a hunch...
Try converting 3dpolyline into its corresponding spline prior doing creating mesh - use spline instead of 3dpolyline... Should do it corrctly...
For conversion look into attchments posted in this topic :
https://www.theswamp.org/index.php?topic=49959.0
(You have to have www.theswamp.org membership to access the topic - key routine is 2ndss2spls.lsp and there are also important ones that follows in next post - I mean important to 2ndss2spls.lsp - Suggestion is to load them all before applying (c:2ndss2spls) inside your code...)
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
