Revision of Viewports in the model
jorgearone_inssitu
jorgearone_inssitu
Hello everyone, I would like to see if there is already a lisp that can do this
It is to make a quick check if all the drawings are included in the layout.
This drawing is an example
I have a drawing with 3 Layouts (Lay_1, Lay_2, Lay_3)
Each Layout is Respectively as seen
Lay_1
Lay_2
Lay_3
then through a Lisp to be able to  can mark each view of the layouts in the model (each layout with a different color, starting with 1, 2, 3 ...), and that the name of the layout appears in the center of the closed figure of the Layout
In such a way that the drawing can remain on the model like this
paullimapa
this code almost gets you there by drawing the vport outline for each vport in all layouts
the layout labelling and color designation shouldn't be that difficult:
Solved: Re: Outline projection all viewports to model - Autodesk Community - AutoCAD
Paul Li
IT Specialist
@The Office
jorgearone_inssitu
Thank you so much
