revcloud problem
revcloud problem
revcloud problem
hencoop
I looked at your drawing and could not see any obvious problem.
You will need to describe the problem before anyone will know what the problem is.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
Kent1Cooper
If you're trying to convert Polylines into Revclouds, and it doesn't look like it's working, you may just have really tiny arc segments in the results, and need to use the command's Arc length option first, and set reasonable sizes for the scale of the drawing.
Kent Cooper, AIA
