Hi there,
We have a large LISP project that adds labels to a polyline, like so:
This is very similar to Civil3D, but we had to recreate it in AutoCAD as Civil3D isn't an option for us.
A label consists of multiple entities (MText and Hatch objects). In the NOD, we store the entity handle of the polyline, along with the entity handles of all the label entities, like so:
The polyline handle here would be F011, and the polyline segment would be 0, and inside the XRecord "HANDLE_BOBBEGIN" is the string value 6FB90.
We use entity handles as they remain unchanged when saving, closing and opening a DWG file.
We use a single object reactor to react to changes to the entities. This is created as follows:
(defun REA:CREATE_GLOBAL ()
(vlr-pers
(vlr-object-reactor (list) ; owner registry, defaults to nil
"WATERNET_REACTOR"
'((:vlr-modified . REA:HANDLE_MODIFIED)
(:vlr-erased . REA:HANDLE_ERASED)
(:vlr-unerased . REA:HANDLE_UNERASED)
(:vlr-goodbye . REA:HANDLE_GOODBYE)
(:vlr-modifyUndone . REA:HANDLE_MODIFY_UNDONE)
The :vlr-modified event works great. All our handlers look like this (same parameters used by all events):
(defun REA:HANDLE_MODIFIED ($parentVla $reactor $parameters / ...)
We get the VLA-object of the polyline that is currently reacting, the reactor, and parameters, which is always nil.
We then use (vlax-vla-object->ename) to convert the VLA-object to an ENAME, which allows us to perform (entget) to retrieve the polyline handle. We can then use this handle to update our label entities, retrieved from the NOD.
So, our main goal is to retrieve the entity handle of the current object reacting. However, when using :vlr-erased and :vlr-openedForModify, we run into the following issues:
- :vlr-erased
- (vlax-vla-object->ename) + (entget) returns nil, as the entity is flagged as deleted
- (vla-get-Handle) throws "Automation Error. Object was erased"
- :vlr-openedForModify
- (vla-get-Handle) throws "Automation Error. Object was open for write"
We fully understand the limitations of LISP, so we are trying to figure out a way to work around this. In the end, we just need to be able to get the entity handle of the VLA-object that is reacting, so that we can retrieve the label data.
We are currently trying an approach where we create a map/dictionary in-memory with all VLA-objects in the drawing and their associated string handle (key-value map). This map is created upon opening the drawing, and kept up to date when new labels are added. I'll update the post if we know more about how well this approach works, but we wanted to ask the community, hoping for a more creative and clever solution to this problem.
Kind regards,
Sem
