RESOLUTION IN GETPOINT FUNCTION
arpansark0544TCX
Message 1 of 9
arpansark0544TCX
Hello everyone,
Hope you are doing good.
Is there any way to increase the resolution of Getpoint (decimal points) and a way to make z axis 0.
Please help me edit this
(defun c:COOM nil (setq m (getpoint "\nSelect destination point >"))
) ;end defun
Output :
Command: ID
Specify point: X = 344849.3922 Y = 167702.1946 Z = 0.0000
Command: *Cancel*
Command: *Cancel*
Command: COOM
Select destination point >(344849.0 167702.0 -1.99306e-06)
Command: !M
(344849.0 167702.0 -1.9828e-06)
Can the function store the same coordinates as getting by id command.
Thank you in advance.
Replies (8)
Message 2 of 9
pbejse
It doesn't look the same but it is @arpansark0544TCX. What are you planning to use the point data for?
Message 3 of 9
hak_vz
Internal precision is 2 * 10-14, display precision is set to 2 decimal places.
To receive more decimals you can use:
Command: (setq a (getpoint))
(2936.97 1024.77 0.0)
Command: (defun decp (p) (rtos p 2 10))
DECP
Command: (mapcar 'decp a)
("2936.9721898964" "1024.7654693919" "0")
Convert string to real number with desired number of decimal places.
Miljenko Hatlak
Message 4 of 9
Kent1Cooper
What is meant by the red line above?  It's clearly [from the formatting of it] not the return from a (getpoint) function, as the blue line apparently is.  The differences in the X and Y coordinates between them are not just a matter of how many decimal places are displayed [or the blue X & Y would not end in .0], so where is the red coming from, that is, how do you know it's supposed to be that, differing from the blue?
I assume you are getting the blue from a cursor pick, presumably Object-snapping to something that has a not-quite-exactly-zero Z coordinate [it's very close].  If you want that to come back with 0.0 for the Z coordinate, read about the OSNAPZ System Variable.
Kent Cooper, AIA
Message 5 of 9
arpansark0544TCX
I am getting from ID command on the specific point with only CENTRE osnap on. On the other hand I am getting blue from the stored value of getpoint . I used only CENTRE osnap in this too. I have made sure that my OSNAPZ System Variable is set to 1 with elevation to 0.00.
Message 6 of 9
arpansark0544TCX
Ok, I get it Internal precision is 2 * 10-14, and display precision is set to 2 decimal places.
So no matter what it is showing !M will paste the object in its exact location.
Message 7 of 9
arpansark0544TCX
To move heavy blocks
Message 8 of 9
calderg1000
Regards @arpansark0544TCX
To move blocks the "MOVE" command is enough, but if you need to customize it here you have some options
;Move block by selecting points arbitrarily
(defun c:mb (/ ss en)
  (setq ss (ssget '((0 . "insert")))
        en (ssname ss 0)
  (vl-cmdf "_move" en "" pause pause)
;Move block by selecting previously known points
(defun c:mb1 (/ ss en p1 p2)
        en (ssname ss 0)
        p1(getpoint"\np1: ")
        p2(getpoint p1 "\np2: ")
  (vl-cmdf "_move" en "" "none" p1 "none" p2)
;Move block automatically selecting its insertion point
(defun c:mb2 (/ ss en pins)
        en   (ssname ss 0)
        pins (cdr (assoc 10 (entget en)))
  (vl-cmdf "_move" en "" "none" pins pause)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 9 of 9
arpansark0544TCX
Thank you very much
