Requested a lisp for total area of polygon in table with their layerwise.
paliwal222
Message 1 of 15
paliwal222
Dear all,
requested a lisp of Total Area of various polygon by layerwise in a table in drawing.
OR customization in lisp, or suggest me any link please.
i have loading lisp file that mark area of per polygon in drawing. Drawing also attached.
Thanks.
Replies (14)
Message 2 of 15
Sea-Haven
There was a similar post request maybe 2 weeks ago trying to find, may have been on another forum.
Do a google.
Message 3 of 15
paliwal222
Sir, Thanks for so quick respond.
i load the lisp, but i found this error given below
(LOAD "C:/Users/USER/Desktop/Area by layer in table.lsp") c:ad
Command: AD
Usage: (acad_strlsort <list of strings>)
nil
Link:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/help-adding-total-area-of-polylines-...
Message 4 of 15
pbejse
What is the basis for the column "number"?
Message 5 of 15
paliwal222
 it is to be just serial number.
or if may be possible, total number of polygon or closed polylines, per layer
but it is not necessary.
serial number also not necessary.
Message 6 of 15
paliwal222
I have found a lisp in forum, but its show hatched area. I want just close polyline area in table.
Message 7 of 15
pbejse
Please pick one among all the options you posted @paliwal222 and get back to us.
Message 8 of 15
paliwal222
ok sir,
here i attached the new lisp and autocad file.
now there is no of item per layer and their area.
take a look please
please, modify the attached list to (hatched area layerwise ---- changed in polygon area layerwise in table.)
thanks.
Message 9 of 15
pbejse
@paliwal222 wrote:
ok sir,
now there is no of item per layer and their area. <--
I'm guessing that means number and not the word NO.
(defun c:AreaByLayerWise ( / mysset  e i data  allData   basepoint SupportDrawingTable)
;;;		pBe : Apr 2022			;;;
(if (and
      (setq mysset  (ssget '((0 . "POLYLINE,LWPOLYLINE") (-4 . "&") (70 . 1))))
      (setq basepoint (getpoint "\nPick point for Table:"))
    (progn
	    (repeat (setq i (sslength mysset))
	      (setq e (vlax-ename->vla-object (ssname mysset (setq i (1- i))))
		    data (mapcar '(lambda (p)
				    (vlax-get e p)) '("Layer" "Area")))
	      (setq allData
	      		(if (setq f (assoc (car data) AllData))
			  	(subst (list (car f)(+ (Cadr f)(cadr data))(1+ (caddr f))) f allData)
				(cons (list (car data)(Cadr data) 1)  allData))
        (setq allData (vl-sort allData '(lambda (a b )
				  (cond
				    ((> (caddr a)(caddr b)))
				    ((= (caddr a)(caddr b))(> (cadr a)(cadr b)))))))
	(setq SupportDrawingTable
		       (vlax-invoke
			 (vlax-get (vla-get-ActiveLayout
				     (vla-get-ActiveDocument
				       (vlax-get-acad-object)
				   'Block
			 ) 'Addtable basepoint  2 3 25.0 100.0
      (vla-put-regeneratetablesuppressed SupportDrawingTable :vlax-true)
      (vla-settext SupportDrawingTable 0 0 "Area Table")
      (vla-setcelltextheight SupportDrawingTable 0 0 10.0)
      (mapcar '(lambda (y)
	  	(vla-settext SupportDrawingTable 1 (car y) (cadr y))
	  	(vla-setcelltextheight SupportDrawingTable 1 (car y) 10.0)
		 '((0 "Layer")(1 "Number")(2 "Total Area"))
      (vla-InsertRowsAndInherit SupportDrawingTable 2 1 (length allData))
       (setq row 1)
                (while (setq a (car allData))
                      (vla-settext SupportDrawingTable (setq row (1+ row)) 0 (car a))
		      (vla-settext SupportDrawingTable row 1 (caddr a))
                      (vla-settext SupportDrawingTable row 2 (rtos (* 0.00694 (cadr a)) 2 2))
                      (setq allData (cdr allData))
      (vla-put-regeneratetablesuppressed SupportDrawingTable :vlax-false)
(princ)
HTH
Message 10 of 15
paliwal222
Dear sir thanks. its not so argent.
i try the given lisp but its not working and give message below and its also result a empty table with none of text
Command: AREABYLAYERWISE
Select objects: Specify opposite corner: 17 found
Select objects:
Pick point for Table:; error: bad argument type: numberp: nil
After restart pc, its same problem.
is there some mistake by me?
But overall
"Area of Each hatch by layerwise in table areatable.LSP" is enough for me for my needs at now.
Thanks a lot for so much responding.
ok
Message 11 of 15
pbejse
Not your fault at all @paliwal222
for some strange reason this 0.006944444 became this 0.xxx-xxxxxxxx
Try copying the code again, otherwise, download the attached lisp file
HTH
Message 12 of 15
paliwal222
Dear Sir,
Thanks a lot.
its work properly.
Message 13 of 15
paliwal222
Dear, Sir Patrick,
Thanks again for providing me the code,
but this time I am little greedy
I have the drawing in meter
and also want to area table in meter.(input 1 = 1.000 meter here in this drawing)
I am try to convert the area multiply by 144 but its not give me accurate result
it's a very humble request from me, if code change in sq. meter and also 0.0000 precision
or send me which line i have to change.
thanks again so much.
Message 14 of 15
pbejse
@paliwal222 wrote:
...and also want to area table in meter.(input 1 = 1.000 meter here in this drawing)
You should use the system variable Measurement  to determine if the drawing is metric or imperial
(setq factor (if (zerop (getvar 'Measurement)) 0.00694444 1.00))
and use the value here as multiplier
(vla-settext SupportDrawingTable row 2 (rtos (* factor (cadr a)) 2))
Also use Luprec system variable to determine the decimals
350.0000
HTH
Message 15 of 15
paliwal222
OK sir,
Thanks a lot.
