request to create resetblockbyname.lsp
jtm2020hyo
Message 1 of 19
jtm2020hyo
I need reset a dynamic block in the entire drawing. (regular block, dynamic block, nested blocks) by selecting the block and typing their name.
Replies (18)
Message 2 of 19
Moshe-A
@jtm2020hyo hi,
Can you elaborate on that and provide sample dwg?!
moshe
Message 3 of 19
jtoverka
There is little information within your post. I am confused when you say "by selecting the block and typing their name." Why do you need to do both to reset the block in the drawing? Unless you mean that you can do either to achieve the same result? However, I assume that you want to reset the properties of dynamic blocks to their original values.
Lee Mac has a great library of programs that works with dynamic blocks.
http://www.lee-mac.com/dynamicblockfunctions.html
Message 4 of 19
jtm2020hyo
@Moshe-A wrote:
@jtm2020hyo hi,
moshe
In my attached file I need to reset the block named "#cables" in the whole drawing. such dynamic block need be reset in all kind of blocks (regular blocks, dynamic blocks, nested blocks).
why I need reset all copies of the selected blocks? I modified such block but when use ATTSYNC blocks just update ATTRIBUTES. RESETBLOCK do what I need. but are like 1000 blocks to use it inside.
so I need a batch lisp alternative to reset all copies of selected block or named block.
Message 5 of 19
jtm2020hyo
sorry for my bad English
I mean "by selecting the block OR typing their name"
Message 6 of 19
Moshe-A
@jtm2020hyo hi,
here is a function (ma:globally_reset_dynamic_block) to reset any dynamic block by name.
usage:
(ma:globally_reset_dynamic_block  "YourBlockNme")
if "YourBlockNme" is not exist, an error message is prompt and nil is return. if block is exist then at end a integer number will return which is the number of reset blocks made.
the function will skip xrefs and dependent xref blocks.
your challage is to add error checking to (vla-resetblock) method plus handle lock layers.
enjoy
moshe
(vl-load-com); load activex
(defun ma:globally_reset_dynamic_block (bname / ctr AcDbBlockTableRecord AcDbEntity)
 (if (null (tblsearch "block" bname))
  (prompt (strcat "\nblock " bname " is not exist.\n"))
  (progn
   (setq ctr 0)
   ; allocating memory
   (vlax-for AcDbBlockTableRecord (vla-get-blocks (vla-get-activedocument (acad-object)))
    (if (and
         (eq (vlax-get-property AcDbBlockTableRecord 'isXref) :vlax-false) ; skip xref
         (not (vl-string-search "|" (vla-get-name AcDbBlockTableRecord)))  ; skip xref dependent blocks
     (progn
      ; allocating memory
      (vlax-for AcDbEntity AcDbBlockTableRecord
       (if (and
	     (eq (vla-get-objectName AcDbEntity) "AcDbBlockReference")
	     (eq (vla-get-isDynamicBlock AcDbEntity) :vlax-true)
	     (eq (strcase (vla-get-effectiveName AcDbEntity)) (strcase bname))
        (progn
         (setq ctr (1+ ctr))
         (vla-resetBlock AcDbEntity)
        ); progn
       ); if
       ; dispose memory
       (vlax-release-object AcDbEntity)
      ); vlax-for
     ); progn
    ); if
    (vlax-release-object AcDbBlockTableRecord); dispose memory
   ); vlax-for
   ctr
  ); progn
 ); if
); ma:globally_reset_dynamic_block
Message 7 of 19
Moshe-A
@jtm2020hyo hi,
if the help you got does solved your problem? than mark this as your solution.
thanks
moshe
Message 8 of 19
jtm2020hyo
@Moshe-A wrote:
@jtm2020hyo hi,
usage:
enjoy
moshe
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
I was testing your code, does not work for me.
Command:
PASTECLIP
Specify insertion point: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: *Cancel*
Command: (ma:(ma:globally_reset_dynamic_block  "YourBlockNme"))
block YourBlockNme is not exist.
; error: no function definition: MA:
Command:
PASTECLIP
Command: (ma:globally_reset_dynamic_block "#cables")
; error: no function definition: ACAD-OBJECT
Command: (ma:globally_reset_dynamic_block "#Cables")
Command: Specify opposite corner or [Fence/WPolygon/CPolygon]:
Command: RENAME
Command: RENAME
1 Block renamed
Command: (ma:globally_reset_dynamic_block "cables")
Command: RENAME
1 Block renamed
Command: RENAME
block cables is not exist.
nil
Command:
Command:
Command: _ai_selall Selecting objects...done.
I need to reset block with name #cables.
I tried rename #cables to cables and cables to #cables.
I just received this message "; error: no function definition: ACAD-OBJECT "
ATTACHED tested file.
Message 9 of 19
DannyNL
Change (acad-object) to (vlax-get-acad-object).
(vlax-for AcDbBlockTableRecord (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
Message 10 of 19
Moshe-A
sorry, my mistake, here is the fix
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
Message 11 of 19
jtm2020hyo
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
work perfect for me.
thanks a lot.
A question: How can I modify your lisp code to use typing a command, something like this "c:resetblocksbyname"
Message 12 of 19
Moshe-A
change  "ma:globally_reset_dynamic_block" to "c:resetblocksbyname"
Message 13 of 19
jtm2020hyo
I tried to change as you said, but I have not luck.
attached file lisp is what I tried modify.
Message 14 of 19
Moshe-A
your change is good but the question is what did you do after?
it should be load in order to work - yes?!
Message 15 of 19
Moshe-A
@jtm2020hyo ,
sorry here is the fix:
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
(defun c:resetblocksbyname ()
 (princ)
Message 16 of 19
jtm2020hyo
@Moshe-A wrote:
@jtm2020hyo ,
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
 (princ)
thanks for your reply.
I noticed that "c:resetblocksbyname" command line reset just the block with name "#cables"
...but is possible to type ANY block name after input "c:resetblocksbyname" command line?
Message 17 of 19
Moshe-A
something like this?
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
	     (wcmatch (strcase (vla-get-effectiveName AcDbEntity)) (strcase bname))
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
 (ma:globally_reset_dynamic_block "*")
 (princ)
Message 18 of 19
jtm2020hyo
  (progn
   (setq ctr 0)
   ; allocating memory
    (if (and
     (progn
      ; allocating memory
       (if (and
        (progn
         (setq ctr (1+ ctr))
        ); progn
       ); if
       ; dispose memory
      ); vlax-for
     ); progn
    ); if
   ); vlax-for
   ctr
  ); progn
 ); if
 (princ)
I mean more like: enter command "resetblocksbyname", then write the block name "#tableros" or "*" (using '*' like wildcard), then press ENTER, then all block with the same name are reset.
Message 19 of 19
Moshe-A
@jtm2020hyo ,
here it is ... and you can reply to the prompt with one block name or multiple block names separate with commas:
Enter a block name: BLOCK1
or
Enter a block name: BLOCK1,BLOCK2,BLOCK2
or
Enter a block name: *   ; one asterisk means reset all dynamic blocks
(defun c:resetblocksbyname (/ bname)
 (if (/= (setq bname (getstring "\nEnter block name(s): ")) "")
  (ma:globally_reset_dynamic_block bname)
 (princ)
