Request: LISP that rolls out a polyline
YasserMahran
YasserMahran
Hi all, I was looking for a lisp that takes a polyline like this: (of course it's in a single line, but segments are colored for clarifiying purposes):
and outputs segments of straight line like this:
Kent1Cooper
This came up in December.  Look here.
Kent Cooper, AIA
YasserMahran
Excellent! however for I noticed that it ignores small segments (<0.2), take this polyline as an example, the segment I put the dimension on won't come up when the lisp is applied:
Kent1Cooper
@YasserMahran wrote:
.... it ignores small segments (<0.2), take this polyline as an example, the segment I put the dimension on won't come up when the lisp is applied:
You probably have running Object Snap on, and the short segment's new end is within Osnap distance from the last point.  Either turn running Osnap off [the routine can also be made to do that for you], or change this line:
    (command (polar (getvar 'lastpoint) 0 (car lengths)))
to this:
    (command "_none" (polar (getvar 'lastpoint) 0 (car lengths)))
Kent Cooper, AIA
