Replacing Dimension Text in a Function with Variables
I need to replace the actual dimension text so that it would look like this ----4 spa @ 5'-0 = 20'-0.
Where the "4" is replaced by the variable "qty", the "spa @" is always there, the "5'-0" is replaced with the variable "off", and the "20'-0" is given as the default  "<> "
Any ideas would be appreciated.
;;; Function C:EB ;
;;; Description: Draws equally spaced Beams in a bay ;
;;; 3/11/19 Dale Poston ;
;;; 3/12/19 changed to "EB" and replaced joists references with beams ;
;;; 3/14/19 added saving and restoring layer, OSnap, and Dimstyle ;
;;; added Dimension ;
(defun c:EB (/ p1 p2 p3 d qty off olddim)
;; Save Current Layer
;; Set Current Layer and Object Snap settings
(setq oldlayer (getvar "clayer"))
(ai_sysvar '(("clayer" . "Beam") ("osmode" . 233)))
(setq olddim (getvar "dimstyle"))
(command "_dimstyle" "_r" "kdspacing")
(vl-catch-all-apply
'(lambda ()
;;; get points and number of Beams
(setq p1 (getpoint "\nPick top span point: ")
p2 (getpoint "\nPick bottom span point: ")
p3 (getpoint "n\Pick bottom bay far point: ")
d (distance p2 p3)
qty (getreal "\nHow many Spaces: ")
;;; do the math
(setq off (/ d qty)) ; Offset amount for Beams (equally spaced)
;;; draw line from p1 to p2
(command "line" p1 p2 "")
;;; offset for Beams and erase p1 p2
(if (> d off)(command "offset" off p1 p2 ""))
(if (> d (* 2 off))(command "offset" (* 2 off) p1 p2 ""))
(if (> d (* 3 off))(command "offset" (* 3 off) p1 p2 ""))
(if (> d (* 4 off))(command "offset" (* 4 off) p1 p2 ""))
(if (> d (* 5 off))(command "offset" (* 5 off) p1 p2 ""))
(if (> d (* 6 off))(command "offset" (* 6 off) p1 p2 ""))
(if (> d (* 7 off))(command "offset" (* 7 off) p1 p2 ""))
(if (> d (* 8 off))(command "offset" (* 8 off) p1 p2 ""))
(if (> d (* 9 off))(command "offset" (* 9 off) p1 p2 ""))
(if (> d (* 10 off))(command "offset" (* 10 off) p1 p2 ""))
(if (> d (* 11 off))(command "offset" (* 11 off) p1 p2 ""))
(if (> d (* 12 off))(command "offset" (* 12 off) p1 p2 ""))
(if (> d (* 13 off))(command "offset" (* 13 off) p1 p2 ""))
(if (> d (* 14 off))(command "offset" (* 14 off) p1 p2 ""))
(if (> d (* 15 off))(command "offset" (* 15 off) p1 p2 ""))
(if (> d (* 16 off))(command "offset" (* 16 off) p1 p2 ""))
(if (> d (* 17 off))(command "offset" (* 16 off) p1 p2 ""))
(if (> d (* 18 off))(command "offset" (* 17 off) p1 p2 ""))
(if (> d (* 19 off))(command "offset" (* 18 off) p1 p2 ""))
(if (> d (* 19 off))(command "offset" (* 19 off) p1 p2 ""))
(if (> d (* 20 off))(command "offset" (* 20 off) p1 p2 ""))
(if (> d (* 21 off))(command "offset" (* 21 off) p1 p2 ""))
(if (> d (* 22 off))(command "offset" (* 22 off) p1 p2 ""))
(if (> d (* 23 off))(command "offset" (* 23 off) p1 p2 ""))
(if (> d (* 24 off))(command "offset" (* 24 off) p1 p2 ""))
(if (> d (* 25 off))(command "offset" (* 25 off) p1 p2 ""))
(if (> d (* 26 off))(command "offset" (* 26 off) p1 p2 ""))
(if (> d (* 27 off))(command "offset" (* 27 off) p1 p2 ""))
(if (> d (* 28 off))(command "offset" (* 28 off) p1 p2 ""))
(if (> d (* 29 off))(command "offset" (* 29 off) p1 p2 ""))
(if (> d (* 30 off))(command "offset" (* 30 off) p1 p2 ""))
(command "erase" p1 p2 "")
;; "Dimension" the Beams ;;;
;; Set layer ;;;
(Setvar "clayer" "Dimensions")
(command "dimaligned" p2 p3 "@-36,36" "")
; need to replace the actual dimension text that would look like this ----4 spa @ 5'-0 = 20'-0 ;;;
; where the "4" is replaced by the variable "qty", the "spa @" is always there, the "5'-0" is replaced ;;;
; with the variable "off", and the "20'-0" is given as the default - <> ;;;
;; Reset Layer, OS, and Dimstyle
;(ai_sysvar nil)
(setvar "clayer" oldlayer)
(command "_dimstyle" "_r" olddim)
(princ)
;;; End function
Moshe-A
@Anonymous  hi,
hope this is still actual...
replace this line:
with this line:
(command "._dimaligned" p2 p3 "_text" (strcat (rtos qty 2 0) " spa @ " (rtos off 4) " = <>") "@-36,36")
enjoy
moshe
Thank you.
I had received a solution on another forum which is very close to yours.
I'll try them both and see which is best.
