Replace text with block and transfer value to scale X
Message 1 of 12
Hi. Anyone can help me?
I need to replace text objects with a block, get the value from text and apply it on the X scale (including negative values).
Thank you
Replies (11)
Message 2 of 12
natasha.l
Hello @Anonymous,
Can you provide us with an example of what you are trying to accomplish for some more clarity?
Take a look at this video some of the functionality you are looking for maybe demonstrated.
Thank you.
Message 3 of 12
Hi.
I dont know how to clarify more. I want to create a block on each text with a specific x scale, which is the string value, plus a factor (im ok with that because i can manipulate the text values).  The link for the video does not work.
Message 4 of 12
ara_neresesian
HI
PLEASE MAKE A SAMPLE AND SEND IT.
WE CAN HELP YOU BETTER
AM I RIGHT?
Message 5 of 12
Hi
Exactly! Your capture reflect what i want.
Here is my sample.
in fact i will need 2 blocks, but i can easily handle it.
Message 6 of 12
Moshe-A
@Anonymous  hi,
check this lisp. wrap the following codes line in text file call it apsc.lsp and appload it.
enjoy
moshe
(vl-load-com)
; apply scale
(defun c:apsc (/ get_block_name askString net_digits ; local functions
	         default ss elist sx)
 (defun get_block_name (def / flag blk)
  (while (not flag)
   (if (eq (setq blk (getstring (strcat "\nBlock name <" def ">: "))) "")
    (setq blk def)
   (if (null (tblsearch "block" blk))
    (progn
     (vlr-beep-reaction)
     (prompt (strcat "\nBlock " blk " is not exist."))
    ); progn
    (setq flag t)
   ); if
  ); while
  blk
 ); get_block_name
 ; return only digits
 (defun net_digits (str / i ch num)
  (setq i 1 ch (substr str i 1) num "")
  (while (/= ch "")
   (if (or
	 (eq ch ".")
	 (eq ch "+")
         (eq ch "-")
         (and
	  (>= (ascii ch) 48)
	  (<= (ascii ch) 57)
    (setq num (strcat num ch))
   ); if
   (setq i (1+ i) ch (substr str i 1))
  ); while
  num ; return
 ); net_digits
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 ; set default
 (if (eq (getvar "users5") "")
  (setq default (setvar "users5" "1"))
  (setq default (getvar "users5"))
 (if (and
       (setvar "users5" (setq bname (get_block_name default)))
       (setq ss (ssget '((0 . "?text"))))
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq elist (entget ename))
    (if (setq sx (atof (net_digits (cdr (assoc '1 elist)))))
     (command "._insert" bname "_none" (cdr (assoc '10 elist)) sx 1 0)
   ); foreach
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
Message 7 of 12
Yeah, it worked! I only have problems with zero values, but i can easily replace them.
Thank you very much!
Message 8 of 12
in that case it should draw nothing or apply a small value.
Message 9 of 12
Moshe-A
@Anonymous ,
replace this:
with this ...to skip insert the block when text value is 0.00
    (if (and
	  (/= (rtos sx 2 2) "0.00")
Message 10 of 12
For some reason didn't work.
"Value must be nonzero.
; error: Function cancelled
Message 11 of 12
Moshe-A
@Anonymous ,
sorry (you are right)
replace this line:
 with this line:
(/= sx 0)
Message 12 of 12
It worked!
Thank you!!!
Final Code:
(vl-load-com)
; apply scale
  (while (not flag)
    (setq blk def)
    (progn
     (vlr-beep-reaction)
    ); progn
    (setq flag t)
   ); if
  ); while
  blk
 ); get_block_name
  (while (/= ch "")
   (if (or
	 (eq ch ".")
	 (eq ch "+")
         (eq ch "-")
         (and
	  (>= (ascii ch) 48)
	  (<= (ascii ch) 57)
   ); if
  ); while
  num ; return
 ); net_digits
 ; set default
 (if (and
    (if (and
	  (/= sx 0)
   ); foreach
 ); if
 (princ)
