Replace last character of hex string
yan_ken
Message 1 of 11
yan_ken
How do I replace the last HEX character of a HEX string of any length with an asterisk* in my LISP code?
Ken
Replies (10)
Message 2 of 11
cadffm
I can't understand, hex character/hex string/ asterix, please post an example
before you have Input <postyourexamplestring>
after work you like to have Output <newoutput>
Sebastian
Message 3 of 11
Ranjit_Singh
There might be many ways to do this depending on your specific needs. Top of my head
(strcat (vl-list->string (reverse (cdr (reverse (vl-string->list "your string"))))) "*")
Message 4 of 11
john.uhden
Another way is:
(strcat (substr str 1 (1- (strlen str))) "*")
where str is the symbol for your text value.
John F. Uhden
Message 5 of 11
Kent1Cooper
@cadffm wrote:
I can't understand, hex character/hex string/ asterix, please post an example ....
Just so you know....  "Hex" refers to a hexadecimal [base-16] number.  In AutoCAD, strings representing them are used for entity handles, for example in this entity data list:
Command: (entget (car (entsel)))
Select object: ((-1 . <Entity name: 1759c4e76e0>) (0 . "LINE") (330 . <Entity name: 175bf4951f0>) (5 . "1E6") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbLine") (10 38.5837 21.8194 0.0) (11 35.0213 15.0763 0.0) (210 0.0 0.0 1.0))
"1E6" is the Line's handle, a hexadecimal number [=  (1 x 16 squared)  +  (14 [the E] x 16)  +  6].  Whether or not the request has anything to do with entity handles, if that's the example hex string, presumably they want to change that to "1E*".  @john.uhden's suggestion is probably the simplest way to do that.
Kent Cooper, AIA
Message 6 of 11
cadffm
 "presumably they want to change that to "1E*"
"Just so you know.." -
Thanks for explaining very much, I know what hex spelling/Syntax and an Asterix is, but
The request is not clearly described enough (for me) and I was not sure what the thread-opener meant.
Ranjit & John show just how the last character of a string can be changed, I've also typed on it,
But technically this has nothing to do with HEX and the solution sounds too easy for a question so formulated.
("hex String" ok, but "hex character" ? I hoped for a more exciting task ;D )
And "1E*" had make no sense for me. If handle: "Handle and the next 15 objects" would make sense, but "1E *"?
So I asked directly the only one that is surely knowing what he has and wants.
I will read continue here, thank you.
Sebastian
Message 7 of 11
yan_ken
Thanks for all the information, Folks.
Basically, I have a hex string,for example h=8B7EDF and I need to do a if statement if this string with the exception of the last hex character matches with any of the following hex strings
For example:
h=8B7EDA
h=8B7EDB
h=8B7EDC
h=8B7EDD
so I was thinking of replacing the last hex character h=8B7ED*
I don't know if wildcard match is possible with hex string.
Thanks very much
Message 8 of 11
Ranjit_Singh
Yes wcmatch should work. In your case if h is the variable then this
(wcmatch h "8B7ED*")
will return T for all your mentioned values of h. But note that * goes for anything (single character, or number or multiple characters /numbers. If you just want to check a single character, then use
(wcmatch h "8B7ED?")
Message 9 of 11
yan_ken
So if my hex variable is say "myhexstring" = 2H7EB
would the following replace the last hex character B with a *?
(strcat (substr myhexstring1 (1- (strlen myhexstring))) "*")
my variable length is not always 5 hex characters,,, could be any length... but I just want to replace the last hex character with *
Thanks again
Message 10 of 11
ВeekeeCZ
There are used 4 functions in the expression.
strcat
substr
1-
strlen
Please use the HELP to see what they do!!! No other functions are simpler!
Message 11 of 11
john.uhden
Hex codes are just strings, so wildcard matching is perfect.
Just be careful, because the * at the end can mean a match with any number
of following characters. Perhaps you want to match any of just the last
character, in which case use ? instead of *.
John F. Uhden
