Replace dimension text/value
Henrik_Lo
Message 1 of 14
Henrik_Lo
Hi
Is there a lisp routine the can replace dimension text/value. It need to find the text and replace it with a new one.
Regards
Henrik
Replies (13)
Message 2 of 14
cadffm
Unless you have a Lisp,
use QSELECT to find them and change the Textoverride value in your Properties palette[CTRL+1]
Sebastian
Message 3 of 14
Henrik_Lo
HI
I am looking for a simple lisp program to do this, but QSelect is also a fine tool.
Regards
Henrik
Message 4 of 14
hak_vz
Here is the post on this forum about this subject but some modifications are needed.
Using Qselect is easiest and quickest option.
Miljenko Hatlak
Message 5 of 14
Henrik_Lo
HI, thangs for replying, I will take a look into this thread.
Regards
Henrik
Message 6 of 14
TonyRB
@TonyRB - this post has been edited due to Community Rules & Etiquette violation.
Doesn't work...
Message 7 of 14
Kent1Cooper
@TonyRB wrote:
Doesn't work....
That is never enough information.
Kent Cooper, AIA
Message 8 of 14
TonyRB
I don't have time to be verbose...sorry.
Message 9 of 14
Kent1Cooper
On the assumption that you posted in hopes of getting some direction on an approach that would work [if not, why bother?], a little bit of verbosity might allow someone to actually help you.  But we can't on the basis of what you posted.  What do you mean by "doesn't work"?  What does the approach in the Message you replied to not do that you want it to, or do that you don't want?  Etc., etc.
Kent Cooper, AIA
Message 10 of 14
pendean
Community Legend
Community Legend
@pendean - this post is being edited to remove content.
@TonyRB wrote:
Doesn't work..
Message 11 of 14
Kent1Cooper
@pendean wrote:
... bearing in mind that in Dimensions, FIND can work only with override text content, not with the actual-measurement text.  You can't FIND all Dimensions of [for example] 1'-4" if that's their text content because it's the actual measurement, and give them override text content to replace or add to that.
@TonyRB was replying to @cadffm , whose Message suggested using QSELECT.  [Maybe FIND works in a way that QSELECT "doesn't work" for them -- we can't know yet.]  QSELECT is capable of finding Dimensions by measured value, or by Text override.  We don't know which of those kinds of content is what anyone is looking to find, but both are "reachable" one way or another.
Kent Cooper, AIA
Message 12 of 14
TonyRB
Neither method, QSELECT, FIND worked with the Text Override I needed to find...thank you.
Message 13 of 14
Kent1Cooper
FIND should do that if you're talking about Text Override content, not measured value.  In addition to what @pendean pointed out [blue here], make sure the yellow-highlighted options here are on or off appropriately for what you want to find:
Kent Cooper, AIA
Message 14 of 14
TonyRB
It worked after I edited the options menu...dummy me.
