replace block with new block, but keep attribute
michaelZCXYL
Message 1 of 11
michaelZCXYL
I am wondering if it is possible to replace old blocks, but keep attribute value, thank you very much in advance.
Replies (10)
Message 2 of 11
3wood
You can either redefine the block definition or try MBLOCKREPLACE. (Only applicable to same attribute tags)
Message 3 of 11
Sea-Haven
If you remake the block in another dwg with same attribute tag, then copy and paste to other dwg it should ask to redefine, then use attsync. Used this on old dwgs when corporate logo changed in title block.
Message 4 of 11
ВeekeeCZ
Even the built-in Express Tools BLOCKREPLACE can do that.
Message 5 of 11
michaelZCXYL
Thank you very much all of you. I want to use dynamic block to replace old block. I can't find mblockreplace command in AutoCAD2023, is it an app lisp? Block replace did not work, please see image below,
Could you please advise me how to redefine block? I edit block and keep the change, it looks like good, but I can't change attribute location. I tried remake same name and same tag block in another dwg, it did not work. I tried it again later, thanks again.
Message 6 of 11
pendean
Community Legend
Community Legend
@michaelZCXYL You missed the hidden link in that reply, here it is https://sites.google.com/site/cadkits/home/mblockreplace
None of the tools above work on dynamic blocks AFAIK: you ought to have stated as much in the first place. Lets see if that can get edited.
Message 7 of 11
michaelZCXYL
I did not know it, but I can create new static block or change dynamic block to static block. My questions remain, thanks a lot!
Message 8 of 11
Sea-Haven
If its a dynamic block it would have a new name ? So get old block info including atts, erase then insert dynamic block and set atts or dynamic properties. Use Lee-mac dynamic block.lsp Not a simple task.
Message 9 of 11
michaelZCXYL
Hello, thank you very much all of you.  😀
Message 10 of 11
yannTCJWH
When I have this kid of message, I just type name of this dynamic block and it's work.
You can use RIblock from cad -studio for this kind of replace with dynamic
https://www.cadstudio.cz/en/download.asp?file=RIblock
sincerly
Message 11 of 11
michaelZCXYL
Many thanks.
