Reorder Attributes values
C.Utzinger
Message 1 of 54
C.Utzinger
Hi
I have the attached block with one Attribute.
I'm looking for a Lisp code to reoder the given values. Like:
EG-001, EG-002, EG-003, EG-003, EG-007, EG-010 ---> EG-001, EG-002, EG-003, EG-004, EG-005, EG-006.
I tried some codes i found in other Forums, but nothing worked.
Please help...
Replies (53)
Message 21 of 54
pbejse
@C.Utzinger wrote:
Sorry I take so much time from you...
Thanks again!
No worries, i needed the practice.
add num before the last parenthesis of the _padZero subfunction.
(defun _padZero (num md)
(setq num (strcat "0" num))
      (while (< (strlen num) md)
      num
HTH
Message 22 of 54
C.Utzinger
Now it counts correct, but i found a strange thing :(, sorry for hard testing :).
See the attachment.
Message 23 of 54
pbejse
"EG-01002"  <--what the?????  Hahaha
Its an easy fix, but go ahead and try it with more formats and values and report all the bugs and quirks you encounter. I'll be here.
Message 24 of 54
C.Utzinger
It was not a new formatSmiley Very HappySmiley Very HappySmiley Very Happy
It should be EG-1002 Smiley Very Happy
But I will try more...
Message 25 of 54
C.Utzinger
I think that is all.
I found another strange thing but i think it's the same like the other one.
Can you please fix this, I hope that is all.
Thank you again and again...
Message 26 of 54
C.Utzinger
Just for understanding...
There will be no more formats, Smiley WinkSmiley WinkSmiley Wink.
I think i should have postet this before. Smiley FrustratedSmiley FrustratedSmiley Frustrated
Message 27 of 54
pbejse
      num
If there are no other bugs, I think that should do it. There was an extra line there before the while function
HTH
EDIT: Yeah, you should have at the get-go. Anyway. I had fun
Cheers
Message 28 of 54
C.Utzinger
COOOLLLL Thank you!!!
Post the hole code for Solution!
Kind regards
Message 29 of 54
pbejse
Here at    Autodesk Community Logo  customer satisfaction is our priority.
 bcm.jpg "One is glad to be of service".
pBe
Message 30 of 54
C.Utzinger
HI
I have a Little problem...
I had to change the textformat of the block and know the code dont work with only numbers (001, 002, 003).
Could give help me please, i tried to modify the code but it is to much for me.
Attached the changed block, there is no width 0.7 anymore...
Thank you...
Message 31 of 54
C.Utzinger
I think i have a solution!!!
I changed the spilt function and now it works
(defun _split (lst i / numbers)
	(while (< 46  (setq n (if (/= i 0)(nth (setq i (1- i)) lst) (setq i (1- i)))) 58)
			(setq numbers (cons n  numbers)))
      	(if (and numbers
                 (setq str (vl-list->string lst)))
		 (list (substr str 1 (1+ i)) (vl-list->string numbers))))
Is that so OK, or i just made a very stupid thing? Smiley LOL
Message 32 of 54
pbejse
Well good for you Cree-G.
Haven't had the chance to try your mod yet. If it works for you then go for it. It's a learning opportunity for you.
Tell us how it goes.
Message 33 of 54
C.Utzinger
HI
I hope you remember this thread.
I was trying to rewrite the code for an other block (attached), but i failed.
Could you please help me with it?
Kind regards
Message 34 of 54
pbejse
@C.Utzinger wrote:
 ..I hope you remember this thread.
Just barely.
@C.Utzinger wrote:
..I was trying to rewrite the code for an other block (attached), but i failed...
I saw the blocks, Not sure what FillTheGap.lsp objective was, I'll have a look and get back to you in a few.
Message 35 of 54
pbejse
Question for you, are the values will be a as simple as "A".... "R" or "1" to "12"? no dash or any other symbol like "EG-100"?
Message 36 of 54
C.Utzinger
HI
Yes, just A to Z, and 1 to max. 99.
I would be cool to have the posibility to switch between numbers an chars, from A to 1 or 1 to A.
Thank you in advance.
Kind regards
Message 37 of 54
C.Utzinger
And
Message 38 of 54
pbejse
@C.Utzinger wrote:
....Yes, just A to Z, and 1 to max. 99.
Kind regards
(Defun c:FTGST  ( / opt start ss attVal_collection attval)
;;		Fill The Gap Section Tag  	;;
;;		pBe Feb 2018		  		;;
(initget 1 "Letter Number")
(setq opt (getkword "\nChoose option [Letter/Number]: "))
(setq start
		  (cond
		    	(	(and (eq opt "Letter")
		  			(setq str_T (strcase (getstring (strcat "\nEnter start Letter <" (cond (str) ("A")) ">: "))))
					(setq str (cond ((snvalid str_T ) (strcase str_T)) (str) ("A")))
					(wcmatch str "[A-Z]")
					)	(setq sym (list ascii chr))
			 			str
		    (		(eq opt "Number")
			 		(setq num (cond ((getint (strcat "\nEnter start Number <" (itoa (setq num
						              (cond ( num ) ( 1 )))) ">: "
						    ) ( num ) ))
					(setq sym (list atoi itoa))
					(itoa num)
	(if (and
		 start
		 (setq attVal_collection nil
			 ss (ssget "_:L" '((0 . "INSERT")
	                       (66 . 1)
	                       (2 . "spi-schnitt,`*U*"))))
		  (progn
		    (repeat (setq i (sslength ss))
				(setq e (vlax-ename->vla-object  (ssname ss (setq i (1- i)))))
				(if
				  (and
				    (eq "SPI-SCHNITT" (strcase (vla-get-effectivename e)))
				    (setq
					 attval (mapcar
							(function
							  (lambda	(at / num)
							    (list	(vla-get-tagstring at)
									(vla-get-textstring at)
									at
							(vlax-invoke e 'Getattributes)
				    (vl-every '(lambda (tag)
							  (member (Car tag) '("LINKS" "RECHTS"))) attval)
						 (cons
						   (list (cadar attval)
							    (mapcar 'last attval)
						   attVal_collection
		    (foreach itm (vl-sort attVal_collection '(lambda (a b) (< (car a) (car b))))
			 	(cond
					(	(eq (Car itm) start)	)
				   	(	(mapcar '(lambda (at)(vla-put-textstring at start)) (cadr itm))	)
				  (setq start (1+ ((car sym) start))
			 		   start ((cadr sym) start)
	  (princ (strcat "\n<<< "
	    (cond
		 (	(null start) (setq str nil) "Invalid Input >>>"	)
		 (	(null ss)	"Null Selection >>>"		)
  (princ)
Command: FTGST
Choose option [Letter/Number]: L
Enter start Letter <F>: a
Select objects: Specify opposite corner: 4 found
Select objects:
Command: FTGST
Choose option [Letter/Number]: N
Enter start Number <1>:
Select objects:
HTH
Message 39 of 54
C.Utzinger
HI
Perfect!!! Thank you very much!
I will change it a little bit, so there will be only one request for userinput.
And if it goes over Z I will try to add an alert.
Kind regards
Message 40 of 54
pbejse
@C.Utzinger wrote:
...Thank you very much!
You are welcome, Happy to help
pBe
