Renaming Civil 3D Structures With AutoLisp. Risk?
Message 1 of 1
I have hundreds of Civil 3D structures that I would like to rename. By 'dumping' the AECC_STRUCTURE object I can see the 'DisplayName' property, which is read only, and the 'Name' property.
I have no issues writing to, and updating, the name property. Everything thing seems to work but I'm a bit paranoid that it was too easy and am concerned about dealing serious damage to our Pipe Networks.
Does anyone have insight into this process or a way to verify that I won't do any damage?
Here's the framework:
; Rename structures based on description
(vl-load-com)
(defun NDS_renameStrcs ( / )
	(setq mlist (ssget "X" '((0 . "AECC_STRUCTURE"))))
	(setq i 0)
	(repeat (sslength mlist)
		(setq STRC (vlax-ename->vla-object (ssname mlist i)))
		(setq strIn (vlax-get-property STRC 'Name))
		(if (= (vlax-get-property STRC 'Description) "[CODE]")
			; Do Work
			(progn
				;[CODE]
		(setq i (+ i 1))
	(princ)
Replies (0)
