Rename suffix based on list value
yann_fradier
Message 1 of 29
yann_fradier
Hello everyone and thank you for your help,
I try to adapt the lsp evoked on the forum for my case but that exceeds my competence in this field ^^.
I would like an lsp to rename the suffixes of the layers according to the name of each of them
Example:
Suffixe "02-SURFACE"
Layer list: [ZRAEX;ZEX;ZDECAP]
Example after lsp: 02-SURFACE-ZRAEX
Suffixe "03-CADASTRE"
Layer list: [PARCELLE]
Example after lsp: 03-CADASTRE-PARCELLE
Suffixe "04-topo"
Layer list: [BT,HT,POINT]
Example after lsp: 04-TOPO-BT
Replies (28)
Message 21 of 29
komondormrex
check the following
(defun add_layer_prefix  (layer_list prefix date_list / new_layer_name layer_collection layer_name renamed new_layer)
	(vlax-map-collection (setq layer_collection (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
		'(lambda (layer)
			(if (member (strcase (setq layer_name (vla-get-name layer))) (mapcar 'strcase layer_list))
				(progn
				  	(setq renamed nil)
					(foreach date date_list
						(if (and
							(setq new_layer_name (strcat prefix "-" date "-" layer_name))
							(vl-catch-all-error-p
								(vl-catch-all-apply 'vla-item (list (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
											  						new_layer_name
							(if (not renamed)
								(setq renamed (not (vla-put-name layer new_layer_name)))
							  	(progn
									(setq new_layer (vla-add layer_collection new_layer_name))
								  	(mapcar 'eval
										 (mapcar '(lambda (property) (list (read (strcat "vla-put-" (vl-symbol-name property))) 'new_layer  (vlax-get layer property)))
										         '(Description Freeze LayerOn Linetype Lineweight Lock Material Plottable TrueColor ViewportDefault)
								  	(entmod (subst (assoc -3 (entget (vlax-vla-object->ename layer) '("*")))
										       (assoc -3 (entget (vlax-vla-object->ename new_layer) '("*")))
							(alert (strcat "Layer \"" new_layer_name "\" already exists"))
	(princ)
;to run type in command line (add_layer_prefix '("ZRAEX" "ZEX" "ZDECAP") "02-SURFACE" '("17-11-2023" "17-10-2023" "17-09-2023")) <Enter>
Message 22 of 29
yann_fradier
This time we have a perfect result.
Thank you very much for the valuable and quick help.
Message 23 of 29
pbejse
(defun c:Laypref ( / a b td layname )
(setq td (menucmd "M=$(edtime,$(getvar,date),MO-DD-YYYY)"))
	(While (setq a (tblnext "Layer" (null a)))
	  (setq	layname	(cdr (assoc 2 a))
		b	(entget (tblobjname "layer" layname))
	  (vl-some
	    '(lambda (ln)
	       (if (member layname (car ln))
		 (entmod
		   (subst (cons 2 (strcat (cadr ln) td "-" layname)) (assoc 2 b) b)
	    '((("ZRAEX" "ZEX" "ZDECAP") "02-SURFACE-")
	      (("PARCELLE") "03-CADASTRE-")
	      (("BT" "HT" "POINT") "04-TOPO-")
	)(princ)
Message 24 of 29
yann_fradier
I dare to ask again for your services.
The duplicated source layers contain objects (point, line, block).
Would it be possible for the layers created from your program to duplicate the objects also in similar layers with the new dates?
Message 25 of 29
yann_fradier
Thanks for the feedback,
Komondormex script responds well to my request. I just updated the post because I also want to duplicate the objects present in my source layers to keep them in the new ones.
Message 26 of 29
komondormrex
sure,
check the following
(defun add_layer_prefix  (layer_list prefix date_list / new_layer_name layer_collection layer_name renamed new_layer layer_object_sset layer_processed)
  	(setq layer_processed 0)
		'(lambda (layer)
				(progn
				  	(setq renamed nil)
						(if (and
											  						new_layer_name
							(if (not renamed)
							  	(progn
								  	(mapcar 'eval
								  	(if (setq layer_object_sset (ssget "_x" (list (cons 8 (vla-get-name layer)))))
									  (foreach object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex layer_object_sset))))
									     (vla-put-layer (vla-copy object) new_layer_name)
				  	(princ (strcat "\nLayer \"" layer_name "\" has been processed."))
				  	(setq layer_processed (1+ layer_processed))
  	(if (zerop layer_processed) (princ "\nNo layer found to process."))
	(princ)
Message 27 of 29
pbejse
That's all good and understood @yann_fradier
Tell me if my contribution were able to address your request or is it totally off?
Message 28 of 29
yann_fradier
Yes it works perfectly for a single date
Thank you for your contribution
Message 29 of 29
yann_fradier
It’s perfect and effective!
Thank you for the valuable contribution
