Rename Multiple Blocks Based on a List
don_scribner
Message 1 of 10
don_scribner
Good Morning All,
Does anybody have a lisp that will look at a block name in a list and if it exists, rename that block to a new name?  Company was bought out and the new regime changed all of our part numbers.  I have dozens of templates and hundreds of block in each.  I have many of the blocks in a list as shown below.  So if the list could look at the first part number "F102" and if it existed, rename to "300275" I would be a happy camper.
("F102 " "300275")
("F102-P " "300275-P")
("F102-S " "300275-S")
("F103 " "306259")
("F103-P " "306259-P")
("F103-S " "306259-S")
("F104 " "300274")
("F104-P " "300274-P")
("F104-S " "300274-S")
I  . . .  borrowed a lisp that I found on line but I have never been good at error trapping.  Can somebody set me straight?     Don
(defun c:RMB ( / lstBlocks)
;Rename Multiple Blocks
;Prep
(setq lstBlocks '(
;("old_name" "new_name")
("F102 " "300275")
("F103 " "306259")
;Begin work
(setvar 'CMDECHO 0)
(foreach blk lstBlocks
(command "-RENAME" "b" (car blk) (cadr blk))
);foreach
(setvar 'CMDECHO 1)
;Finish up
(prompt "\nBlock Re-Naming Complete.")
(princ)
);defun
Replies (9)
Message 2 of 10
Kent1Cooper
Does that routine work if all the Block names exist, and you just need to add the checking for that?  If so, maybe [untested]:
  (if (and (tblsearch "block" (car blk)) (not (tblsearch "block" (cadr blk))))
    (command "-RENAME" "b" (car blk) (cadr blk)); then
  ); if
); foreach
It checks not only that the old Block name exists, but also that the new one does not exist, because you can't Rename a Block to a name that's already in use.
Kent Cooper, AIA
Message 3 of 10
don_scribner
No, it doesn't even do that. . .
Message 4 of 10
paullimapa
also make sure list of blocks don't contain spaces after the block name...try this:
; RMB renames old block to new block name per given list
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rename-multiple-blocks-based-on-a-list/m-p/11727959#M443191
;Prep
(setq lstBlocks '(
;("old_name" "new_name") make sure no spaces after block name
("F102" "300275")
("F102-P" "300275-P")
("F102-S" "300275-S")
("F103" "306259")
;Begin work
(setvar 'CMDECHO 0)
(if(and
     (tblsearch "BLOCK" (car blk)) ; chk if old block name exists
     (not(tblsearch "BLOCK" (cadr blk))) ; chk if new block name exists
 (progn
   (command "-RENAME" "_B" (car blk) (cadr blk))
   (princ
    (strcat"\nOld Block Name: [" (car blk) "] successfully renamed to\nNew Block Name: [" (cadr blk) "].")
 ) ; progn
 (princ
   (strcat"\nOld Block Name: [" (car blk) "] NOT renamed because it does NOT exists or\nNew Block Name: [" (cadr blk) "] already exists in current drawing.")
 ) ; else
) ; if
);foreach
(setvar 'CMDECHO 1)
;Finish up
(princ)
);defun
Paul Li
IT Specialist
@The Office
Message 5 of 10
pbejse
@don_scribner wrote:
("F102 " "300275")
("F103 " "306259")
Better yet, use an external source for the old-new layer names. that way you can add more layer names.
(defun c:RMB ( / ListOfBlocksSource source linesOnSource p old new)
(if
   (setq ListOfBlocksSource (getfiled "List of New block names" (getvar 'dwgprefix) "csv" 16 ))
  	(progn
	  (setq source (open ListOfBlocksSource "r"))
	  (While (setq linesOnSource (read-line source))
	    	(if (and
			(setq p (vl-string-position 44 linesOnSource))
			(tblsearch "block" (setq old (substr linesOnSource 1 p)))
			(not (tblsearch "block" (setq New (substr linesOnSource (+ p 2)))))
		  (command "-RENAME" "b" old New)
	  (close source)
	  (prompt "\nBlock Re-Naming process complete.")
  (princ)
command: RMB
If the location and name of the data source is always on the same folder.
Change this
to
 (setq ListOfBlocksSource "c:\\Data\\New Regime.csv")
HTH
Refer to attached csv file (New Regime.csv)
Message 6 of 10
don_scribner
Thank you all for helping with my issues.  I really appreciate the time spent. This last iteration has worked very well.
Message 7 of 10
thecocuk07
hello
How do we do it if there is spaces?
Message 8 of 10
Sea-Haven
@thecocuk07 A block name can have spaces. Personally try to avoid. Is what your trying to achieve not working so provide a sample dwg and text in the dwg with Old & New names.
Message 9 of 10
thecocuk07
Before I answer you. I reviewed the problem again. I had a problem with the csv file I used. I fixed it now and the problem is solved. Lisp works perfectly. Thank you for your interest.
Message 10 of 10
Sea-Haven
No worries express thanks to @pbejse he did the most work.
