Rename layout for multiple files.
bmanalanDX6VM
Message 1 of 14
bmanalanDX6VM
I have multiple files with the same layout name.  I would like to rename the layout for all those files. (350 dwg files). Any suggestions.
Replies (13)
Message 2 of 14
Moshe-A
Message 3 of 14
cadffm
Command to rename a layout is LAYOUT
and a simple script for oldname Layout1 and the new name "newname"
_layout
_rename
Layout1
newname
_qsave
and because of possible mistake (drawing files without the oldname-Layout, or files with already have the newname layout)
use this one as script content (The
(if (and
(member (strcase "Layout1") (mapcar 'strcase (layoutlist)))
(not(member "NewName" (mapcar 'strcase (layoutlist))))
(command "_.LAYOUT" "_RENAME" "Layout1" "NewName" "_.QSAVE")
Sebastian
Message 4 of 14
ec-cad
You will be needing a Lisp that 'batches' drawings in a given folder, loads a rename type lisp,
and saves the drawings with the changes. Here's a couple of Lisps to do that.
You need to edit both of the routines. One needs a path to newlayoutname.lsp, and the
other needs your 'NewLayoutName; and 'OldLayoutName.
The main Lisp that allows for drawing folder selection and batching is: ChgLayoutName.lsp
Once loaded, type in CHGLAYOUTNAME at the Command prompt to run.
Place the newlayoutname.lsp somewhere on your drive, and put in that path/lispfilename
in the ChgLayoutName.lsp, so it can 'load' it for each drawing.
Cheers
ECCAD
Message 5 of 14
bmanalanDX6VM
Thank you for your suggestions.
I tested this command on the drawing (command "_.LAYOUT" "_RENAME" "MCW" "AHC" "_.QSAVE")
The layout name changed from MCW to AHC which is what I want. What should the command look like to run this for all files within "Myfolder" or would that be a lisp file to run.
Message 6 of 14
ec-cad
Download the 'ChgLayoutName.lsp and the 'newlayoutname.lsp from above.
Edit the 'newlayoutname.lsp to place your old and new layout names. Save the file in C:/mylisp  folder.
Save the 'ChgLayoutName.lsp in C:/mylisp  folder also.
Edit the 'ChgLayoutName.lsp, put in your path as "C:/mylisp/newlayoutname.lsp", save the file.
Open any drawing. At Command line, do: (load "c:/mylisp/ChgLayoutName.lsp") or drag/drop it into your drawing.
At Command Prompt line, type in:  CHGLAYOUTNAME<enter key>
You will get a dialog to select a Folder, browse, and select your folder.
The program will run and replace the Layout names and save the drawings also.
ECCAD
Message 7 of 14
bmanalanDX6VM
Hello Eccad,
I am not seeing any Lisp files for download. We you say download "from above" what is the location or site?
I appreciate your help and if I can get these files, your instructions make sense.
Thank you.
Message 8 of 14
bmanalanDX6VM
I am not seeing any Lisp files for download. When you say download from above, what is that location or site?
Sorry if I am being a pain in the butt, but if I can get the lisp files, your instructions make sense.
Message 9 of 14
paullimapa
I see them both @ec-cad 10:00am reply posting:
Re: Rename layout for multiple files. - Autodesk Community
Paul Li
IT Specialist
@The Office
Message 10 of 14
ec-cad
It may be a Web Site issue, this AutoDesk site was updated recently.
If you cannot locate the Lisp files I posted, I'll post them here again.
Cheers!
ECCAD
Message 11 of 14
bmanalanDX6VM
I see them on my phone. I added some new security on my computer earlier this week. Anyway, thank you again. I will look at it tomorrow.
Message 12 of 14
Sea-Haven
Maybe look at Accoreconsole it will zoom through 350 dwg's compared to using a script. Hint @paullimapa has a good link about how to use.
https://through-the-interface.typepad.com/through_the_interface/2012/02/the-autocad-2013-core-consol...
 A BAT file approach
:: Path to AutoCAD core console
set accoreexe="C:\Program Files\Autodesk\AutoCAD 2014\accoreconsole.exe"
:: Path to the script to run
set script="C:\Users\[USERNAME]\Desktop\IPAD\TESTER\tester2.scr"
%accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST1.dwg /s %script%
%accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST2.dwg /s %script%
%accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST3.dwg /s %script%
%accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST4.dwg /s %script%
%accoreexe% /i C:\Users\[USERNAME]\Desktop\IPAD\TESTER\TEST5.dwg /s %script%
pause
Message 13 of 14
paullimapa
@bmanalanDX6VM Here's a lisp function to run within AutoCAD that launches AccoreConsole.
First select a folder & then a script file and all the drawings in that folder will be processed with AccoreConsole applying the commands within the script file without needing to open them.
So give this a try.
Paul Li
IT Specialist
@The Office
Message 14 of 14
baksconstructor
If you find it really hard to understand, you can use a ready-made solution. It will quickly do everything you need.
