Rename Layout according to attributes in Titleblock.
Message 1 of 18
Hi!
I have a titleblock called "KN" with attributes tags called "JN" and "NR". I am trying to create a lisp that renames the lisp automatically to  the values of "NR"_"JN", according to the titleblock on the current layout viewport, as all the titleblocks are called KN.
I have been trying the suggestions from this post, but with no success. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rename-layout-to-match-drawing-numbe...
Replies (17)
Message 2 of 18
ahmed.abdelmotey
try this code
you need to verify that title block exists in every layout or it will return an error
(defun c:RenameLayout()
(vl-load-com)
	(foreach lay (layoutlist)
		(setq obj (vlax-EName->vla-Object (ssname (ssget "x" (list (cons 0 "INSERT") (cons 2 "KN") (cons 410 lay))) 0)))
		(if
			(setq lstatts (vlax-SafeArray->list (variant-Value (vla-GetAttributes obj))))
				(foreach atts lstatts
					(cond
						((= (vla-Get-TagString atts) "NR")(setq a (vla-Get-TextString atts)))
						((= (vla-Get-TagString atts) "JN")(setq b (vla-Get-TextString atts)))
				(if
					(not (member (strcat a "_" b) (layoutlist)))
					(command "_Layout" "r" lay (strcat a "_" b))
					(alert "Duplicate Information")
Ahmed Abd-Elmotey
Landscape Architect & beginner lisp programmer
Message 3 of 18
Thanks for the suggestion. I already tried it, but it still gives me the error "; error: bad argument type: lselsetp nil"
Message 4 of 18
ahmed.abdelmotey
this means that the layout doesn't have a block named KN
Ahmed Abd-Elmotey
Message 5 of 18
hmsilva
Try to add a 'progn' in ahmed.abdelmotey's code
(defun c:test ()
    (vl-load-com)
                      (ssname (ssget "_x" (list (cons 0 "INSERT") (cons 2 "KN") (cons 410 lay))) 0)
        (if
               (progn;<<<<
                       (cond
                           ((= (vla-Get-TagString atts) "NR") (setq a (vla-Get-TextString atts)))
                           ((= (vla-Get-TagString atts) "JN") (setq b (vla-Get-TextString atts)))
                   (if
Hope this helps,
Henrique
Message 6 of 18
hmsilva
@ahmed.abdelmotey wrote:
try this code
Hi ahmed.abdelmotey,
to try to avoid the error, test the data, before supply it to a function...
(defun c:test (/ a b lstatts obj ss)
    (vl-load-com)
        (if (and (setq ss (ssget "_x" (list (cons 0 "INSERT") (cons 2 "KN") (cons 410 lay))))
                 (setq obj (vlax-EName->vla-Object (ssname ss 0)))
            (progn
                    (cond
                (if
    (princ)
Hope this helps,
Henrique
Message 7 of 18
ahmed.abdelmotey
thank you for the modification 🙂
Ahmed Abd-Elmotey
Message 8 of 18
hmsilva
You're welcome, ahmed.abdelmotey! 🙂
Henrique
Message 9 of 18
Thanks for the edits. At first it still gave me the error, but then it got to me: my titleblock is not on the layout sheet, but in modelspace. So the titleblock is visible in the viewport.
Is there a way to modify it so, that it would retrieve these values even if the titleblock is in modelspace and is visible on the layout via viewport.
Message 10 of 18
hmsilva
You're welcome, karl_haha!
I have a deadline to meet, so at the moment, I don't have much free time, but I'll see what I can do.
Henrique
Message 11 of 18
hmsilva
Unstested...
(defun c:demo (/ get_att _ctab a b ent hnd i layts ll lstatts msllpt msurpt obj psllpt psurpt ss ss1 ur vlaobj vp)
    (defun get_att (lst tag)
        (vl-some '(lambda (x)
                      (if (= (vla-get-tagstring x) (strcase tag))
                          (vla-get-textstring x)
                 lst
    (if (and (= 0 (getvar "tilemode")) (>= (getvar "cvport") 2))
        (command "_.pspace")
    (setq _ctab (getvar 'CTAB))
    (setq layts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))))
        (setvar 'CTAB lay)
        (command "_.zoom" "_E")
        (if (setq ss1 (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 lay) (cons -4 "!=") (cons 69 1))))
            (progn
                (repeat (setq i (sslength ss1))
                    (setq hnd    (ssname ss1 (setq i (1- i)))
                          ent    (entget hnd)
                          vp     (cdr (assoc 69 ent))
                          VlaObj (vlax-ename->vla-object hnd)
                    (vlax-invoke-method VlaObj 'GetBoundingBox 'll 'ur)
                    (setq psllpt (vlax-safearray->list ll)
                          psurpt (vlax-safearray->list ur)
                          msllpt (trans psllpt 3 2)
                          msurpt (trans psurpt 3 2)
                    (if (not (and (= 0 (getvar "tilemode")) (>= (getvar "cvport") 2)))
                        (command "_.mspace")
                    (setvar 'CVPORT vp)
                    (if (setq ss (ssget "_C" msllpt msurpt (list (cons 0 "INSERT") (cons 2 "KN"))))
                        (if (and (setq obj (vlax-EName->vla-Object (ssname ss 0)))
                                 (setq lstatts (vlax-invoke obj "GetAttributes"))
                                 (setq a (get_att lstatts "NR"))
                                 (setq b (get_att lstatts "JN"))
                            (if
                                (not (vl-position (strcat a "_" b) (layoutlist)))
                                   (vla-put-name (vla-item layts lay) (strcat a "_" b))
    (setvar 'CTAB _ctab)
    (princ)
Hope this helps,
Henrique
Message 12 of 18
ahmed.abdelmotey
without lisp you can create a viewport with the whole size of our paper
make it active and then command : CHSPace and then select your title block
it will be moved to paper space and then the problem shud be solved
Ahmed Abd-Elmotey
Message 13 of 18
Hei Henrique,
thanks for your help.
Sadly this lisp doesn't work. It gives no errors, but it also doesn't change anything. I believe the problem is that it doesn't find the titleblock.
I found this post: http://www.cadtutor.net/forum/showthread.php?60972-extract-data-seen-in-viewport-only-paperspace-dat...
There's a lisp that selects objects only visible in the active viewport. Perhaps it can help?
Ahmed, inresponse to your solution, I need the titleblock to be in model space because it is very hard to identify the drawings without the titleblock as usually I have more than 10 drawings in one file.
Message 14 of 18
hmsilva
@Anonymous wrote:
Hei Henrique,
Could you please attach a sample dwg with some titleblocks?
Henrique
Message 15 of 18
Here you go:
I created a layout as well.
Message 16 of 18
hmsilva
Hi Karl,
the titleblock name is "KN_KONSTR" not "KN"...
Try this quickly revised code
(defun c:demo (/ get_att _ctab a b ent hnd i layts ll lstatts msllpt msurpt obj psllpt psurpt ss ss1 targ ur vlaobj vp)
               lst
      (setvar 'CTAB lay)
         (progn
                     ent    (entget hnd)
               (setvar 'CVPORT vp)
                     targ   (vlax-get VlaObj "Target")
                     msllpt (mapcar '+ (trans psllpt 3 2) targ)
                     msurpt (mapcar '+ (trans psurpt 3 2) targ)
               (if (setq ss (ssget "_C" msllpt msurpt (list (cons 0 "INSERT") (cons 2 "KN_KONSTR"))))
                     (if
                          (progn
                             (setq lay (strcat a "_" b))
   (princ)
Hope this helps,
Henrique
Message 17 of 18
Thanks Henrique, this works brilliantly. 🙂
Message 18 of 18
hmsilva
Glad I could help!
Henrique
