Remove the line string quotes or go to single backslashes....
MBestSNZMY
Message 1 of 11
MBestSNZMY
I'm working on a script file to batch import dgn files into Acad templates then save them as dwg's.
But.....I'm running into multiple limitations.........
-Import works, if I remove backslashes to singles..... But the when I pull the directory and file name from the list, AutoCAD automatically adds the additional backslashes.
EX: "D:\\DGN\\All_Files\\Process_Files\\D17017.dgn"
This I can insert below
i.e. "D:\DGN\All_Files\Process_Files\D17017.dgn"
-Attach and -dgnimport works, but I need to remove the quotes. If I edit manually they work. Trying to do it with command line they do not work.............
A little help and understanding would be greatly appreciated!!
Replies (10)
Message 2 of 11
MBestSNZMY
;;To remove quotes, (Works with -attach and -dgnimport) this works but I can't use strname as the name in -import or attach.  I'm guess strname needs to be changed to something else to use as the filename and location?
I did find this:
(setq strName (read "D:\\DGN\\All_Files\\Process_Files\\D17017.dgn"))
Returns:  D:\\DGN\\ALL_FILES\\PROCESS_FILES\\D17017
;;To remove backslashes, (Works with -import) this works but I can't use strname as the name in -import or attach.  I'm guess strname needs to be changed to something else to use as the filename and location?
Message 3 of 11
paullimapa
Questions
Are you using lisp code to create a script file for AutoCAD to run at a later date?
How are you getting the dgn files names?
Paul Li
IT Specialist
@The Office
Message 4 of 11
MBestSNZMY
I need to do all this in a .scr file
I create a text file with the dgn full path and file name listed.
Read the file name and save it as txtline (setq txtline (read-line f))
Soooo, this file name looks like "D:\\DGN\\ALL_FILES\\PROCESS_FILES\\D17017.dgn"
Using vl-string-translate, I get the slashes opposite
(setq txtline (vl-string-translate "\\" "/" txtline))
"D:/COOL_ORANGE/MITSUBISHI/ALL_FILES/PROCESS_FILES/D17017"
Then using the read command (setq strName (read txtline))
(setq txtline (read TXTLINE))
If I copy and paste the above in the save line it works. I can't get the string to save to the file name and dir.
Running the -save or .save command txtline or !txtline will not present the file name and location to save it. It will always save it as txtline.dwg
This is driving me nuts!! I've read 1000's of lines of code today and nothing really pops up and "Oh crap, you're overthinking it!!
Message 5 of 11
Moshe-A
@MBestSNZMY  hi,
why do you have to change th "\\"  to   "/" ?  you can leave it as it is.
when you call the (read) function with a string args, it returns the string as a SYMbol type but for the script you need string. there is a different when input is coming from keyboard versus script \ autolisp.
So to conclude:
do not use (vl-string=translate)
do not use (read)
Moshe
Message 6 of 11
MBestSNZMY
Sounds simple but.
Read the file name and location in the txt file
Command: (setq f (open "D:\\All_Files\\Process_Files\\DGN_file.txt" "R"))
#<file "D:\\All_Files\\Process_Files\\DGN_file.txt">
Command: (setq txtline (read-line f))
"D:\\All_Files\\Process_Files\\D17017.dgn"
Command: (close f) nil
Remove the .dgn extension
Command: (setq txtline (strcat (vl-filename-directory txtline) "\\" (vl-filename-base txtline)))
"D:\\All_Files\\Process_Files\\D17017"
Check the file name
Command: !txtline
Attempt to save the file using !txtline string as the new filename.  This ends up saving the file as !txtline.dwg instead of the new file name....
Command: -SAVE
SAVE Save drawing as <C:\Users\mikeb\OneDrive\Documents\Drawing19.dwg>: !txtline
Message 7 of 11
Moshe-A
@MBestSNZMY
Read about TEXTEVAL sysvar and tell me what did you think?
Message 8 of 11
MBestSNZMY
Moshe-A,
I can stop drinking now! Setting that to took care of all my issues!! I was overthinking it.
Thank You!!
Mike
Message 9 of 11
MBestSNZMY
Moshe-A, if you're going to AU this year, I owe you a beer!!
Mike
Message 10 of 11
Moshe-A
@MBestSNZMY
Was thrill to see your respond.
I do not know what AU is and do not drink mush beers so pass this to your love one from me 😍
Thank you
Message 11 of 11
MBestSNZMY
Autodesk University in Las Vegas Nov. 13-15, 2023. CAD nerd fest.
