Remove spaces in bearing-distance LISP output
EBDBC3D
EBDBC3D
How can I remove spaces at the "N" and "E" in the output of this LISP routine? For example, to go from N 89°30’30” E   100.00' to N89°30’30”E   100.00'. Thanks!
Kent1Cooper
Replace this line:
(setq brng (angtos ang 4 4))
with this, to strip the spaces out of it [nested, because (vl-string-subst) substitutes only the first instance]:
(setq brng (vl-string-subst "" " " (vl-string-subst "" " " (angtos ang 4 4))))
[That's specific to this case, assuming the string returned by (angtos) for Surveyor's Units (the first 4), which will have 2 and only 2 spaces in it.  If you want to strip spaces out of something that might have any number  of spaces, a (while) loop approach would be needed.]
Kent Cooper, AIA
EBDBC3D
That worked - thanks!
john.uhden
Checkout the UNITMODE system variable.
John F. Uhden
