Remove item from list/ add item to a list
Message 1 of 12
hi all,
i have the following question,
(setq a (5.2, 25))
(setq b (12.3. 56))
(setq c (15.3,16.2))
(setq d (18.3,17.9))
(command "pline" a b c d "")
suppose the values in setq c and setq d is zero or nil, then (command "pline" a b c d) will be error. so, i have to remove c and d (because its value is nil) from the list by checking its value and make the command as (command "pline" a b ""). so, how can i make this? please help me. am using autocad 2017.
thanks in advance
Accepted solutions (4)
Replies (11)
Message 2 of 12
dbroad
First: Be sure to post AutoLISP questions in the AutoLISP customization forum.
Second:  Take a few hours to learn the basics of LISP.  Your AutoLISP posts reveal extreme unfamiliarity with it's syntax.  I suggest http://www.afralisp.net/autolisp/ as a place to start. Autolisp can be a real boon but forums are not a real good place to start learning.
Autolisp, for example, interprets the first item of a list as a function unless it is quoted to avoid direct evaluation.  AutoLISP lists do not use commas.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 12
john.uhden
Well, your structure is a little errant.  You can't...
You could create a list...
(setq c (list 15.3 16.2)) or (setq c '(15.3 16.2))
I don't have a problem with the zeroes, but the nils are certainly no good.
I guess you could break up the command...
(command "_.pline")
(if (vl-every 'numberp a)(command a))
(if (vl-every 'numberp b)(command b))
etc.
John F. Uhden
Message 4 of 12
Kent1Cooper
suppose the values in setq c and setq d is zero or nil, then (command "pline" a b c d) will be error. so, i have to remove c and d (because its value is nil) from the list by checking its value and make the command as (command "pline" a b ""). so, how can i make this? ....
Assuming constructing those things correctly as others have pointed out....
If  you can rely on what's in all those variables to always  be either a point list [a list of 2 or 3 numbers] or nil, and never anything else  [such as a single number -- your zero example -- or text, or something], then you could do this:
(command "_.pline"); leaves you in the command awaiting input
(if a (command a)); feed to PLINE only if it exists [for each]
(if b (command b))
(if c (command c))
(if d (command d))
(command ""); finish Polyline
If any of them ever contain something else, it will cause an error because it will be fed to the PLINE command but will not be acceptable input, or if it is, it will be something like text that is viable for designating an option, and then very likely the next input won't be appropriate for that option.  It would be possible to check not only whether those variables exist but also whether they represent points, with some additional code.
Kent Cooper, AIA
Message 5 of 12
pbejse
@Anonymous wrote:
 ...suppose the values in setq c and setq d is zero or nil, then (command "pline" a b c d) will be error. so, i have to remove c and d (because its value is nil) f
What if either a or b is zero or nil? does it still continue to create the pline using just c and d??
IF the goal is to create a pline whenever there are at least two points.
(if (>= (length (setq lst (vl-remove-if 'null (list a b c d)))) 2)
	(progn
		(command "_pline" )
			(Foreach pt lst (command "_non" pt)
		(command "")
Message 6 of 12
roland.r71
@Anonymous
So... where's the list where you wish to append or vl-remove items???
PLEASE try to use subjects/titles that relate to your question!
Your title refers to a completely different 'problem' Smiley Frustrated
Anyway,
(if b (command b))
(if c (command c))
(if d (command d))
IF the above is true, you might even get away with:
(command "_pline" a b (if c c) (if d d) (if d nil))
Note: if not set, each if reads as nil. (ending the pline command) Any extra nil doesn't break the code (in my simple quick test anyway), but you do need 1 nil to end the pline if all variables are set, so therefor i added an extra (if d nil).
Message 7 of 12
roland.r71
That would be a much beter solution.
Although it would be even beter if the list with points where to be filled with all (valid) points needed.
With a minimum of 2 points, you could create a pline with as many points as you wish.
Message 8 of 12
john.uhden
@Kent1Cooper wrote, "If any of them ever contain something else, it will cause an error "
Please don't tell me you subscribe to the ActivistInvestor method of programming, i.e. having errors tell you that there are errors <splat>.
BTW, "any" is singular... ""If any of them ever contains ..."
BTW, (if a (command a)) might bite you in the butt...
Command: (setq a (list nil nil))
(nil nil)
Command: (defun is (x) (not (not x)))
IS
Command: (is nil) nil
Command: (is a) T
a may be a list, but its contents are nils.  That's why I used (vl-every 'numberp a)
John F. Uhden
Message 9 of 12
roland.r71
(nil nil)
IS
Command: (is a) T
Hence the disclaimer, that a,b,c & d should (must) be either a valid point list or nil. Anything else = error.
It's not the pinnacle of lisp programming, but it works, with minimal effort.
IF you're absolutely sure 'a' will never be a list containing nils, then why check?
Message 10 of 12
john.uhden
I'm not even sure I will wake up in the morning.
John F. Uhden
Message 11 of 12
roland.r71
But i'm 100% sure you have to pay your taxes, untill you don't wake up. Smiley LOL
Message 12 of 12
john.uhden
@john.uhden wrote:
"I'm not even sure I will wake up in the morning."
@roland.r71 replied:
"But i'm 100% sure you have to pay your taxes, untill you don't wake up."
Yes, that's for sure.  A very sad circumstance.  :[
John F. Uhden
