Remove duplicate points from a list
Message 1 of 13
Chaps,
Can anybody speed up this code that removes duplicate coordinates from a list? Six points obviously isn't a problem but I'm working mainly with 100k points.
(setq TRI_Points '((0.0 0.0 0.0) (0.0 0.0 0.0) (10.0 0.0 0.0) (10.0 0.0 0.0) (0.0 0.0 0.1) (10.0 0.0 0.0)))
; stripped to :  '((0.0 0.0 0.0) (10.0 0.0 0.0) (0.0 0.0 0.1))
(setq TRI_StrippedPoints (list (car TRI_Points))
      TRI_Points (cdr TRI_Points)
(repeat (length TRI_Points)
  (setq TRI_checkpoint (car TRI_Points)
	TRI_checkX (car TRI_checkpoint)
	TRI_checkY (cadr TRI_checkpoint)
	TRI_checkZ (caddr TRI_checkpoint)
	TRI_check T
  (foreach TRI_temp TRI_StrippedPoints
    (setq TRI_tempX (car TRI_temp)
	  TRI_tempY (cadr TRI_temp)
	  TRI_tempZ (caddr TRI_temp)
    (if (and
	  (equal TRI_tempX TRI_checkX 0.0001)
	  (equal TRI_tempY TRI_checkY 0.0001)
	  (equal TRI_tempZ TRI_checkZ 0.0001)
      (setq TRI_check nil)
  (if TRI_check
    (setq TRI_StrippedPoints (append TRI_StrippedPoints (list TRI_checkpoint)))
  (setq TRI_Points (cdr TRI_Points))
Replies (12)
Message 2 of 13
patrick_35
Hi
For example
(while TRI_Points
  (setq lst (cons (car TRI_Points) lst)
	TRI_Points (vl-remove (car TRI_Points) TRI_Points)
(reverse lst)
An another from @_gile
(defun remove_doubles (lst)
  (if lst
    (cons (car lst) (remove_doubles (vl-remove (car lst) lst)))
(remove_doubles '((0.0 0.0 0.0) (0.0 0.0 0.0) (10.0 0.0 0.0) (10.0 0.0 0.0) (0.0 0.0 0.1) (10.0 0.0 0.0)))
Message 3 of 13
(setq TRI_StrippedPoints nil)
(setq n 0)
	(setq item (nth n TRI_Points))
	(if (not (member item TRI_StrippedPoints))
		(progn
			(setq TRI_StrippedPoints (cons item TRI_StrippedPoints))
		);progn
	);if
	(setq n (1+ n))
);repeat
Message 4 of 13
CADaSchtroumpf
An another one, I don't know if is fastest!
(defun remove_multi ( l / nw_l )
  (mapcar
    '(lambda (x)
      (if (not (member x nw_l))
        (setq nw_l (cons x nw_l))
    l
  nw_l
(remove_multi tri_points) -> ((0.0 0.0 0.1) (10.0 0.0 0.0) (0.0 0.0 0.0))
Message 5 of 13
Thanks to all.
I had started along these lines but then headed off along the "compare" route which was clearly the wrong direction.
Message 6 of 13
Kent1Cooper
Another way:
(foreach pt TRI_Points
  (if (not (member pt TRI_StrippedPoints))
    (setq TRI_StrippedPoints (cons pt TRI_StrippedPoints))
  (reverse TRI_StrippedPoints); [only if necessary]
or, if you want them in the original order, a way without the (reverse) function:
    (setq TRI_StrippedPoints (append TRI_StrippedPoints (list pt)))
  TRI_StrippedPoints
But I do wonder:  If any of these points could come from some kind of calculation, such as a (polar) function based off another point, or extracted from objects' entity data compared with something like Object-snap selections of the same points, and they wouldn't always be "clean" whole-number coordinates, then you might get points that are "duplicates" for your purposes but that AutoLisp would not consider the same [i.e. with differences 12 or 15 decimal places down].  If such things are possible, a comparison function using (equal) with a fuzz factor, such as in your code in Post 1, would be needed.
Kent Cooper, AIA
Message 7 of 13
stevor
Cannot figure what direction you meant,
but a common method of removing doubles
is, as Kent mentioned, by the proximities.
L would be your list of 3 element lists, ie points;
and D as the nearness distance, maybe 1e-14,
or even 1e-4 for manual measurements.
  ; remove_doubles,  SomeBuddy+
  (defun L_RemEqu (L D / X)
    (cond ((atom L) L)
       (T (cons (car L) (L_RemEqu
         (vl-remove-if '(lambda (x) (equal (car L) X D)) L) D)))) ) ;
For very big lists, a slightly different code may be needed.
S
Message 8 of 13
martti.halminen
If we are having performance problems due to long lists, using APPEND is a bad idea: it has to copy all its arguments except the last. The CONS + REVERSE trick is much faster.
One undocumented trick for the comparisons: EQUAL works with a fuzz factor also for lists of numbers in addition to single numbers, so you can compare the whole point at once instead of each coordinate separately.
Message 9 of 13
Ah yes: CONS v APPEND. One I normally follow. I had APPEND in the original test code to ease comparison between the two lists but neglected to change it to CONS for the final.
Thanks again to all.
Message 10 of 13
stevor
Appears that Gile's is the fastest of a few tested:
Note that some only remove the 'duplicates'
to the Autocad exactness.
Points: 5000, Duplicated in place: 400
Remove_Multi: 3.6090E+00, Rem: 4600
Remove_Doubles: 2.9850E+00, Rem: 4600 [ Gile ]
PL_RemEqua: 1.1390E+01, Rem: 4600
L_RemEqu: 1.6203E+01, Rem: 4600
; Remove Equals, resolution D, explicit, SCG,etal
(defun PL_RemEqua ( L D / U Q F V ) ;
   (while (setq P (car L)) (setq L (cdr L) F NIL V U)
     (while (setq Q (car V)) ; terminate on find,
        (if (equal P Q D) (setq F T V nil) (setq V (cdr V))) )
           (if (not F) (setq U (cons P U)))
    ) (reverse U) ) ; def ~1/3 speed of CADaStroumph, Remove_Multi
S
Message 11 of 13
patrick_35
Hi
The result of benchmark
Elapsed milliseconds / relative speed for 131072 iteration(s):
(REMOVE_DOUBLES TRI_POINTS).....1887 / 1.23 <fastest>
(PATRICK_35 TRI_POINTS).........1904 / 1.22
(KENT1COOPER1 TRI_POINTS).......2168 / 1.07
(KENT1COOPER2 TRI_POINTS).......2215 / 1.05
(REMOVE_MULTI TRI_POINTS).......2278 / 1.02
(THAVASI1982 TRI_POINTS)........2325 / 1 <slowest>
An another
(PATRICK_35 TRI_POINTS).........1903 / 1.24 <fastest>
(REMOVE_DOUBLES TRI_POINTS).....1935 / 1.22
(KENT1COOPER1 TRI_POINTS).......2246 / 1.05
(REMOVE_MULTI TRI_POINTS).......2262 / 1.04
(KENT1COOPER2 TRI_POINTS).......2293 / 1.03
(THAVASI1982 TRI_POINTS)........2355 / 1 <slowest>
(defun patrick_35(TRI_Points / lst)
  (while TRI_Points
  (reverse lst)
  (if lst
(defun thavasi1982(TRI_Points / n item TRI_StrippedPoints)
  (setq n 0)
	    (progn
	    );progn
	  );if
	  (setq n (1+ n))
  TRI_StrippedPoints
  (mapcar
    '(lambda (x)
    l
  nw_l
(defun Kent1Cooper1(TRI_Points / pt TRI_StrippedPoints)
(defun Kent1Cooper2(TRI_Points / pt TRI_StrippedPoints)
    TRI_StrippedPoints
(benchmark (list '(patrick_35 TRI_Points) '(remove_doubles TRI_Points) '(thavasi1982 TRI_Points) '(remove_multi TRI_Points) '(Kent1Cooper1 TRI_Points) '(Kent1Cooper2 TRI_Points) ) )
Message 12 of 13
martti.halminen
Another trick you can try on performance-critical code: VL-POSITION is clearly faster than MEMBER (or at least it was last time I measured it).
- in general code I don't recommend this (unless you are really interested in the position), as it hides the programmer intent.
- This is an implementation error in AutoLISP: as VL-POSITION does more work, it should actually be slower, so the MEMBER implementation is somehow bungled.
Message 13 of 13
joselggalan
another method:
(defun RemoveEqualPts (LstPts fuzz / lstRet)
  (mapcar (function (lambda (pt / )
   (if (not (vl-some (function (lambda (x) (if (equal pt x fuzz) x nil))) lstRet))
    (setq lstRet (cons pt lstRet))
   );c.if
  )) LstPts)
  lstRet
 );c.defun
example:
(RemoveEqualPts
 0.0001
