Remove Dimension Overrides
se.ha
Advisor Advisor
se.ha
Hi community.
I export dwgs from revit. For whatever reason, dimensions with superscript text get overridden. I want to delete the overrides but need to exclude certain dimensions. The overrides I need to exlude start with "<>\X". Any ide why my code doesnt work as intended meaning every override gets deleted?
(defun c:RemoveDimOverrides ( / dimlist ent entdata override)
  (defun starts-with (str prefix)
    (and (>= (strlen str) (strlen prefix))
         (eq (substr str 1 (strlen prefix)) prefix)))
  (setq dimlist (ssget "X" '((0 . "DIMENSION")))) ; Select all dimensions in the drawing
  (if dimlist
    (progn
      (setq i 0)
      (while (< i (sslength dimlist))
        (setq ent (ssname dimlist i))
        (setq entdata (entget ent))
        (setq override (cdr (assoc 1 entdata)))
        (if (and override ; Check if an override exists
                 (not (starts-with override "<>\\X"))) ; Check if the override does not start with "<>\\X"
          (progn
            (setq entdata (subst (assoc 1 entdata) (cons 1 "") entdata)) ; Remove override
            (entmod entdata) ; Save changes
        (setq i (1+ i))
      (princ "\nOverrides have been removed.")
    (princ "\nNo dimensions found.")
  (princ)
(princ "\nType 'RemoveDimOverrides' to remove dimension overrides.")
(princ)
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
pendean
Community Legend
Community Legend
May I ask, why not the built-in ability (assuming, like all of us, you have a well defined DIMSTYLE imported from a template in each of these "revit" DWG files)
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-A31420D1-C876-47A5-ACAF-C7DC4F0B3E9E#:~:text=...
Moshe-A
@se-ha
maybe this line, it should be:
(setq entdata (subst (cons 1 "") (assoc '1 entdata) entdata))
Moshe
komondormrex
hey there,
via vla-*
(defun c:RemoveDimOverrides (); / dimlist ent entdata override)
	(and (vl-string-search prefix str)
		 (zerop (vl-string-search prefix str))
  (if dimlist
    (progn
      (setq i 0)
        (if (not (starts-with override "<>\\X")) ; Check if the override does not start with "<>\\X"
		  (vla-put-textoverride (vlax-ename->vla-object ent) "")
        (setq i (1+ i))
  (princ)
(princ)
or
(setq entdata (subst (cons 1 "") (assoc 1 entdata) entdata)) ; Remove override
new member-> old member
se.ha
Thanks @komondormrex and @Moshe-A
Both solutions work.
se.ha
