remove consecutive duplicate points of a pline
kibitotato
Message 1 of 14
kibitotato
¿Is it possible to have a .lsp that removes consecutive duplicate points of a opened or closed pline?
Replies (13)
Message 2 of 14
Kent1Cooper
One way:
EXPLODE the Polyline.
Use QSELECT or FILTER to select all Lines [and possibly Arcs?] of zero length, and ERASE them.
JOIN or PEDIT / Join what's left back into a Polyline.
I expect an AutoLisp routine could be written to do that, if that sounds like what you want.  I also expect there's something like that already out there, available for the Searching.
Kent Cooper, AIA
Message 3 of 14
kibitotato
I´m looking for a quick mode, so a lsp could be perfect. I delete this kind of duplicated points several times in one hour. Found this but doesn´t work properly for me
(defun c:RD (/)
; choose the polyline
  (setq ent (entget (car (entsel))))
  (acet-lwpline-remove-duplicate-pnts ent)
  (princ)
;Takes an entity list of lwpolylines and modifies the object
;removing neighboring duplicate points. If no duplicated points
;are found then the object will not be passed to (entmod ).
;Returns the new elist when done.
(defun acet-lwpline-remove-duplicate-pnts (e1 / a n lst e2)
  (setq n 0)
  (repeat (length e1)
    (setq a (nth n e1)) ;setq
    (cond
      ((not (equal 10 (car a)))
       (setq e2 (cons a e2))
      ) ;cond #1
      ((not (equal (car lst) a))
       (setq lst (cons a lst)
     e2 (cons a e2)
       ) ;setq
      ) ;cond #2
    ) ;cond close
    (setq n (+ n 1)) ;setq
  ) ;repeat
  (setq e2 (reverse e2))
  (if (and e2
   (not (equal e1 e2))
   lst
      ) ;and
    (progn
      (if (equal 1 (length lst))
(progn
  (entdel (cdr (assoc -1 e1)))
  (setq e2 nil)
) ;progn then single vertex polyline so delete it.
(progn
  (setq e2 (subst (cons 90 (length lst)) (assoc 90 e2) e2)
  ) ;setq
  (entmod e2)
) ;progn else
      ) ;if
    ) ;progn then
  ) ;if
  e2
Message 4 of 14
EnM4st3r
what about OVERKILL
Message 5 of 14
kibitotato
yes it works but ideally not quick enought
Message 6 of 14
Kent1Cooper
@kibitotato wrote:
.... Found this but doesn´t work properly for me ....
That is never enough information.  What's not proper about it?
I am skeptical that a custom AutoLisp routine is going to be enough quicker than OVERKILL to justify the effort of writing one.  What makes OVERKILL not quick enough?
Kent Cooper, AIA
Message 7 of 14
kibitotato
I understand.
So, in order to be quicker, is it possible to have overkill without this window???
Message 8 of 14
EnM4st3r
yes, use _-OVERKILL
Example:
(setq ss (ssget  "_X" '((0 . "LWPOLYLINE"))))
(command "_-overkill" ss "" "_PL" "_y" "")
Or without the "_X" for manual selection:
(setq ss (ssget '((0 . "LWPOLYLINE"))))
Message 9 of 14
kibitotato
I think that this works for all objects into the drawing. I want to work it witch only one...
Message 10 of 14
EnM4st3r
yes, with the second one you can select the objects manually
Message 11 of 14
kibitotato
Is it possible to associate it to a shortcut like WQ or something... ? Tried to edit it into .pgp but doesnt work...
Message 12 of 14
EnM4st3r
yes like this. Save as .lsp
(defun c:wq (/ ss)
  (princ)
Message 13 of 14
kibitotato
absolutely perfect!!!! thanks!!!!!!
Message 14 of 14
komondormrex
it is surely possible. check the following.
(defun remove_duplicates (_list / duplicateless_list)
	(while _list
		(if (not (equal (car (setq list_element (car _list))) (caar (setq _list (cdr _list)))))
			(setq duplicateless_list (append duplicateless_list (list list_element)))
(defun c:remove_duplicate_vertices (/ pline_sset deleted_number pline_dxf number_before)
	(if (setq deleted_number 0 pline_sset (ssget ":l" '((0 . "lwpolyline"))))
		(foreach pline (vl-remove-if 'listp (mapcar 'cadr (ssnamex pline_sset)))
			(setq pline_dxf (entget pline)
				  number_before (fix (vlax-curve-getendparam pline))
				  vertices_bulge_list (remove_duplicates (mapcar 'cons (mapcar 'cdr (vl-remove-if-not '(lambda (group) (= 10 (car group))) pline_dxf))
				  										  			   (mapcar 'cdr (vl-remove-if-not '(lambda (group) (= 42 (car group))) pline_dxf))
			(vla-put-coordinates (vlax-ename->vla-object pline)
								 (vlax-safearray-fill (vlax-make-safearray vlax-vbdouble (cons 1 (* 2 (length vertices_bulge_list))))
								 				      (apply 'append (mapcar 'car vertices_bulge_list))
			(setq deleted_number (+ deleted_number (- number_before (fix (vlax-curve-getendparam pline)))))
			(setq index 0)
			(foreach vertex vertices_bulge_list
				(vla-setbulge (vlax-ename->vla-object pline) index (cdr vertex))
				(setq index (1+ index))
			(princ (strcat "\rTotal deleted duplicate vertices: " (itoa deleted_number)))
	(princ)
