Reinsert dynamic blocks and copy over attributes and parameter
Message 1 of 1
Hello everyone! Smiley Happy
Found this code from the forums by Lee Mac that reinsert blocks. The routine works well and really close to what I intend to accomplish but I need the blocks reinserted as the original coordinates for each block and copy over all attributes and parameter settings including visibility. Please help....Thanks in advance!
(defun c:ReInsertAll (/ GetName Blocks ss Model Var Obj)
  (vl-load-com)
  (setq GetName (lambda (obj) (if (vlax-property-available-p obj 'EffectiveName)
                                (vla-get-EffectiveName obj)
                                (vla-get-Name obj))))
  (if (ssget "_X" '((0 . "INSERT") (410 . "Model")))
    (progn
      (vlax-for obj (setq ss (vla-get-ActiveSelectionSet
                               (setq doc (vla-get-ActiveDocument
                                           (vlax-get-acad-object)))))
        (setq Blocks
          (cons
            (list (GetName obj) obj
                  (if (eq :vlax-true (vla-get-HasAttributes obj))
                    (mapcar
                      (function
                        (lambda (attrib) (cons (vla-get-TagString attrib)
                                               (vla-get-TextString attrib))))
                      (vlax-invoke obj 'GetAttributes))))
            Blocks)))
      (vla-delete ss)
      (setq Model (vla-get-ModelSpace doc) Var (vlax-3D-point '(0 0 0)))
      (foreach x Blocks
        (setq Obj (vla-InsertBlock Model Var (car x) 1. 1. 1. 0.))
        (vla-delete (cadr x))
        (if (and (caddr x)
                 (eq :vlax-true (vla-get-HasAttributes Obj)))
          (foreach att (vlax-invoke obj 'GetAttributes)
            (if (setq tag (assoc (vla-get-TagString att) (caddr x)))
              (vla-put-TextString att (cdr tag))))))))
  (princ))
Replies (0)
