Reinforcement diameters lisp
k005
Advisor Advisor
Message 1 of 11
k005
hello friends,
ø How can I list rebars of different diameters in the foundation reinforcement plan _?
sample:
The result I want to get:
ø8
ø10
ø12
ø14
It's enough to write like.
thank you so much.
Replies (10)
Message 2 of 11
hak_vz
Attach sample drawing and provide much more details how you want to have it created; table inside drawing, export to excel....
Miljenko Hatlak
Message 3 of 11
k005
The reinforcement letters in the drawing will be looked at and the different ones will make a table. or text below. talo
will be in dwg. We have nothing to do with Excel. no.
The criterion here is the diameter sign. = ø
Message 4 of 11
Sea-Haven
The dia symbol is an extended character or use %%c see this https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
Or can do as a double input using a suitable dcl with say bar sizes as a list.
Message 5 of 11
pbejse
Do you need a count of items per  rebar size? "6ø14" 6 as the quanity
ø12 = 25
ø14 = 12
or just a list of rebar size?
if its the former, what about this "ø8/15/8/10" <- is that 1 per ?
Message 6 of 11
k005
@pbejse
no . not list.
I just want the names of the iron diameters. We have nothing to do with pieces-length and spacing.
just need iron diameter.
Message 7 of 11
k005
@Sea-Haven
only iron diameter - diameters are needed.
Message 8 of 11
pbejse
("ø8" "ø10" "ø12" "ø14");<--- that is the only size i'm getting
What about this ""ø8/15/8/10" ? is 15 included?
and is this symbol included as shown on the sample drawing? 12 or 15?
Message 9 of 11
k005
@pbejse
We'll take 12.
* the symbol I always use: ø
* we will take the odd or even number on the right side of the symbol (ø).
Like ø8 ø10 ø12.
The parameter symbol is always this: ø . Our action will be accordingly.
Message 10 of 11
pbejse
Keep in mind that on your sample drawing, there are three (3) characters representing the ø, 1 I already mentioned on my previous post, another is  "Æ" -- ascii code 198, and the other as "ø" -- ascii code 248. I suggest you enforce consistency in using only one type of symbol.
This code only targets the symbol that was used in majority on the TEXT entity
(defun c:DSL ( / dS lst string dP dSize p ) ;Diameter Sze List
;;		pBe 2021		;;;
   (if (setq dS (ssget '((0 . "TEXT")(1 . "*ø#*"))))
    (progn
	    (repeat (setq i (sslength dS))
	      (setq string (cdr (assoc 1 (entget (ssname dS
							(setq  i (1- i)))))))
	      (setq dP (vl-string-position 248 string))
	      (setq dSize (substr string (1+ dP)))
	      (vl-some '(lambda (c)
			  (if (setq p (vl-string-position c dSize))
			    	(setq dSize (substr dSize 1 p)))) '(32 47))
	     (if (not (member dSize lst))  (setq lst (cons dSize lst))
      (print
      	(setq lst (vl-sort lst '(lambda (a b)
				  (< (atoi (substr a 2))(atoi (substr b 2))))))
  (princ)
Command: DSL
Select objects:
Replace this line if you prefer the program to read everything on current tab
to
(setq dS (ssget "X" (list '(0 . "TEXT")'(1 . "*ø#*")(cons 410 (getvar 'Ctab)))))
HTH
Message 11 of 11
k005
@pbejse
Thank you so much. Super! This is exactly what it is. 🤗
