regroup a group you have ungrouped in AutoLisp
Message 1 of 28
I hope you enjoyed the title
Hello, I'm new to my job and I'm asked to rotate an object inside a group, without rotating it as a whole.
The only way I'm seeing is to ungroup it, rotate the said object and regroup the objects once more.
The problem is, I don't know how to identify every member of the group before ungrouping, so i could make a list to regroup later.
I hope you understood my problem and any parallel thinking is welcome, since this is my third day using AutoLisp
Replies (27)
Message 2 of 28
ronjonp
No need to ungroup the items. Set the variable PICKSTYLE to 2, rotate your object(s) then set it back to what you had it before.
Message 3 of 28
CodeDing
@ronjonp ,
That would have saved me some heartache Smiley LOL
@Anonymous ,
My take before rperez's info haha:
(defun c:RGO ( / e eCopy grps gName)
;Rotate Group Object
;get object
(setq e (car (entsel "\nSelect object in Group to rotate: ")))
;create copy of item for command call
(setq eCopy (entmakex (cdr (entget e))))
(command-s "_.ROTATE" eCopy "")
;replace original ent with our copy
(if (and (setq grps (GetGroupNames))
	 (setq gName (GroupNameOfEntity e grps)))
  (progn
    (command "-GROUP" "a" gName eCopy "")
    (command "-GROUP" "r" gName e "")
    (if (entget ecopy) (entdel e))
    (prompt "\nRGO Complete..")
  );progn
;else
  (prompt "\nSomething went wrong!")
);if
(princ)
);defun
(defun GetGroupNames ( / ret dict)
;returns list of pairs (("group1name" . Group1Ename) ("group2name" . Group2Ename) ...)
(setq ret '())
(setq dict (entget (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_GROUP")))))
(foreach x dict
  (if (= 3 (car x)) (setq ret (cons (cons (cdr x) (cdr (cadr (member x dict)))) ret)))
);foreach
(if (> (length ret) 0) ret nil)
);defun
(defun GroupNameOfEntity (e pairList / )
;searches all groups for original entity, returns group name that it exists in
(setq ret nil)
(foreach x pairList
  (setq tmp (entget (cdr x)))
  (if (member (cons 340 e) tmp) (setq ret (car x)))
);foreach
ret
);defun
Best,
~DD
Message 4 of 28
ronjonp
Hahaha 🙂 quick test and also using CNTRL and select will modify the objects independent of the group.
Message 5 of 28
Thank you very much, it was just what I needed and simple.
Thank you too, @CodeDing, I didn't run the code but for what @ronjonp showed, it would have worked too 🙂
Message 6 of 28
ВeekeeCZ
There is an icon right on the Ribbon that switch the 'pickstyle this way.
Message 7 of 28
cadffm
The main place for pickstyle/group selection mode is at 'Selection' Tab of Options dialog, command OPTIONS.
CTRL+R is also a toggle für group-selectionmode, same as the button, but independent of current ribbon tab.
Sebastian
Message 8 of 28
martin_leiter
Hello rperez,
I have another question about this useful Lisp.
With the object selection in this Lisp one can select only one object.
How can I select multiple objects in the same group?
can you show me this?
Thank you!
Greetings Martin
Message 9 of 28
ronjonp
@martin_leiter wrote:
Hello rperez,
Thank you!
Greetings Martin
All you have to do is hold down the CTRL key before making your selection then modify as needed. No code necessary.
Message 10 of 28
martin_leiter
Thank you for your answer.
Unfortunately, I can not raise a window. I can only choose 1 object with their code. The CTRL key does not help here.
Or am I doing something wrong?
greetings Martin
Message 11 of 28
ВeekeeCZ
@ronjonp wrote:
All you have to do is hold down the CTRL key before making your selection...
Do you have some magic ctrl key? Because with my regular one it is not working like that.
The only thing that works to me with ctrl is polyline sub-selection.
Message 12 of 28
ronjonp
Not sure if it's magical but it works 🙂 I have AutoCAD '19 & '20 and it works in both? Could be a combination of another variable set that makes it work. I'll have to investigate.
Message 13 of 28
ronjonp
 @ВeekeeCZ what is pickadd set to on your system? If it's 0 then the sub selection will not work.
Message 14 of 28
martin_leiter
For me Pickadd is on 2
greetings Martin
Message 15 of 28
ВeekeeCZ
Yep, pickadd is 2. (acad 2020)
Tried all values, no relation to the issue.
Message 16 of 28
ronjonp
You're right .. I was picking the objects individually and not a crossing selection.
Message 17 of 28
ВeekeeCZ
No, no... can't select them either way.
What type of entities are on your gif, are they polylines? That could work. But not if they are lines or anything else
Message 18 of 28
martin_leiter
Mine are rectangles
greetings Martin
Message 19 of 28
ronjonp
greetings Martin
If you set PICKSTYLE to 0 as mentioned in my first post then make your edits and set the variable back then code still is not necessary :).
Message 20 of 28
ronjonp
Yup .. that's the issue. I had all polylines in the group. Other items do not work. That seems a bit half baked ;/
