Regarding:Some of Lisp File Failing to load in Autocad 2016
Message 1 of 13
My lisp File is loading and Working Fine in Autocad 2014 ,The Same lisp File i loaded in AUtocad 2016.It seems to be Not working.
The above message came when i clicked a ribbon,which point to a lisp file,that working fine in 2014,Only in 2016 the above message came,Anyone can Please help.
Dilipan.s
Replies (12)
Message 2 of 13
hmsilva
Dilipan.s
Hi Dilipan,
after you click the ribbon, if you press F2 key do you see the all the error message?
Using AC2015+ It is required to use command-s calls inside an error handler, instead command calls...
If you post your code, It would be easier to some of us try to assist.
Hope this helps,
Henrique
Message 3 of 13
(defun C:GHD_INSBLOCK (/)
(ghd_curset)
(setvar "insunits" 4)
(command
"attdia" "1"
;; "-layer" "m" ghd_laynam "" ;layer set by calling GHD_TEXT_LAYER.lsp (CAM)
"-color" "bylayer"
"-linetype" "s" "bylayer" "")
(searchfile (strcat GHDBLOCKNAME ".dwg"))
(prompt "\nInsertion Point: ")
(command "-insert" (strcat CAMS_CLIENTPATH GHDBLOCKNAME) pause (* 1 SCALE) "" "0" )
(ghd_prevset)
(defun C:GHD_INSBLOCK_ROT (/)
(ghd_curset)
(command
"attdia" "1"
"-color" "bylayer"
(command "-insert" (strcat CAMS_CLIENTPATH GHDBLOCKNAME) pause (* 1 SCALE) "" pause )
(ghd_prevset)
(defun C:GHD_INSBLOCK_TX50 (/)
(ghd_curset)
(command
"attdia" "1"
;; "-layer" "m" ghd_laynam "c" "1" ghd_laynam "" ;layer set by calling GHD_TEXT_LAYER.lsp (CAM)
"-color" "bylayer"
(command "explode" "l" "ddedit" "l" "" "chprop" "l" "" "la" ghd_laynam "")
(ghd_prevset)
(defun C:GHD_INSBLOCK_TX35 (/)
(ghd_curset)
(command
"attdia" "1"
;; "-layer" "m" ghd_laynam "c" "2" ghd_laynam "" ;layer set by calling GHD_TEXT_LAYER.lsp (CAM)
"-color" "bylayer"
(ghd_prevset)
(princ)
This is my lisp file
Diliapn.S
Message 4 of 13
hmsilva
I would suggest to remove the ATTDIA setting from the command call and use a (setvar 'ATTDIA 1), but the error message should refer to (ghd_curset) or (ghd_prevset) functions...
Henrique
Message 5 of 13
HI Silva,
Thanks For Replying,I try that and  Inform u.
Dilipan.S
Message 6 of 13
I changed as u said,
Same status now showing Different Error Now
After chaning Same status,its working in Acad 2014,but not in Acad 2016.
In 2014
In 2016
Dilipan.S
Message 7 of 13
hmsilva
Dilipan, could you please post the modified code?
Henrique
Message 8 of 13
Hi Silva,
The same above code only,I just Replaced ATTDIA with (setvar 'ATTDIA 1)
For ur Information I m not a lisp Programmer.I m a .net Auto-cad Api developer.So I m struggling with this
Dilipan.S
Message 9 of 13
hmsilva
The revised code should be something like this
    (ghd_curset)
    (setvar 'attdia 1) ; <- add by me
    (setvar 'cecolor "BYLAYER") ; <- add by me
    (setvar 'celtype "BYLAYER") ; <- add by me
    ;|(command
	"attdia"
        "-color" "bylayer" "-linetype" "s" "bylayer" "")<- commented by me |;
    (command "-insert" (strcat CAMS_CLIENTPATH GHDBLOCKNAME) pause (* 1 SCALE) "" "0")
    (ghd_prevset)
    (ghd_curset)
    ;|(command
        "attdia" "1"
    (command "-insert" (strcat CAMS_CLIENTPATH GHDBLOCKNAME) pause (* 1 SCALE) "" pause)
    (ghd_prevset)
    (ghd_curset)
    ;|(command
 	"attdia" "1"
    (ghd_prevset)
    (ghd_curset)
    ;|(command
 	"attdia" "1"
    (ghd_prevset)
(princ)
In these four commands, the code calls three external functions that are defined in another place/code, they are:
ghd_curset, searchfile and ghd_prevset
Most likely one/more than one of those external functions is generating the error in AC2016, you'll have to search the file in which these functions are defined to replace the command call to a command-s...
Henrique
Message 10 of 13
Hi silva,
Thanks for ur Faster Response .
I m going to Change nearly 500 lisp Files ,all maximum contains this ghd_curset,
function can i Replace all Command to Command-S,Whether Its a correct Way?
Thanks&Regards,
Dilipan.S
Message 11 of 13
dbroad
@Anonymous
It doesn't appear that you are defining an *error* function in your code.  Since that is probably the case, it is safe to assume that the code errors are coming from somewhere else.
You can test to see if it is your code by just cause an error at the command line.
(/ 2 0) ;should do it.
If you see the same message, then  it is probably caused by code somewhere else.  I suggest that you redefine the *error* handler as;
(defun *error* (msg) (if msg (princ msg)(princ));;The simplest error handler
or delete the errant error handler by just
(setq *error* nil)
In ACA 2015, the problem was caused by a poorly written LSP file written by an Autodesk developer.  Hot fixes and service packs should take care of it.  Make sure you are up-to-date with those.
To insulate your code from any rogue error handler, just declare the *error* variable local in your functions.
(defun blahblahblah ( your arguments / *error* your local vars)  blah blah blah )
In case this helps, I am posting the problem file from 2015.  It should be safe for you to replace that file in your installation.
Your last error message means that there is a missing external file as hmsilva indicated.
Architect, Registered NC, VA, SC, & GA.
Message 12 of 13
dbroad
@Anonymous
(setq *error* nil)
Message 13 of 13
hmsilva
@Anonymous wrote:
Hi silva,
Hi Dilipan,
you don't have to change the 500 .lsp files...
I did ask you to find the ghd_curset (and the others) function to see if it have an error handler in it...
Henrique
