I loaded many lisp files by using below autoload function.but some of lisp files failed to load on Startup,but if we load Indiviually its Working Fine.
Whether My load function is wrong,By the way I m not a lisp Programmer,So please anyone Guide me.
I saved the Below as Acaddoc.lsp and loaded via Trusted locations.
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/ALIGN_TEXT_ALT.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/ArxLoad.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/AutoBlockBreakV1-7.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/BFind.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/BLCC.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Block_Annotative_Match_Orientation.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Boreholes.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/CircularWipeout.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/COLORX.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/CopyRenameBlockV1-5.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/CopySwapTextV1-4.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/DDLyrAdd.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/DDLyrCas.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/DDLyrOn.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/DDLyrTh.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/DTCurve.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/FindReplaceALL.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/HATCHTOOLS.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/IncArrayV1-7.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/LenCal V1.7.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/MacAttV3-1.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Netload.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/ObjectAlign.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/PTManagerV2-4.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Random.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Alert.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Annotate.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Config.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS DR2CAD.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Drainage.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Miscellaneous.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS MX2CAD.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS NRS2.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS PageSetup.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/RMS Palettes.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/SetoutPoints.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Steal.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/StripMtext.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/Supersede.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/TabSortV2-2.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/TfNSW Annotate.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/TrialPits.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/UTB.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/VLXLoad.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/WILDCARD SYNTAX.lsp")
(LOAD "N:/GLOBAL/APPS RESOURCES/AUTODESK/AUTOCAD/2014/Client Library/2100047/SOC/Lisp/XRV2.lsp")
Dilipan.S
