Ref object (line) for the rotation of dimension
skchui6159
skchui6159
There are the error found in below lisp. ,; error: bad argument type: symbolp nil
;Set Object to ref for same angle (a line for reference);
I want to select the rotated dimension for rotation to same angle of the line.
There are my code.
(vl-load-com)
(Defun C:sameangle()
(setq q1 (car (entsel "\nPlease Select the Object (Line) for reference of same angle:")))
(setq obj (vlax-ename->vla-object q1))
(setq angobj (vla-get-Angle obj))
(setq n 0)
(setq ss1 (ssget))
(Repeat (sslength ss1)
(set ent (ssname ss1 n))
(setq q1data (entget ent))
(entmod (subst (cons '50 angobj) (assoc 50 q1data) q1data))
);End Repeat
(setq n (1+n))
);End of Defun
Anyone know?
skchui6159
Also the arrow direction ref to the line
komondormrex
corrected for dims
(setq n 0)
(setq ss1 (ssget))
(setq ent (ssname ss1 n)) ;	set->setq
(setq n (1+ n))		 ;	(1+n)->(1+ n)
);End Repeat
skchui6159
Thank you very much
