Is there an autolisp way to redirect the keyboard function keys (F1,F2...) to execute lisp commands ?
Gery
Gery
Since AutoCAD uses CUI editor to assign all the function keys as well as other keyboard combination keys, I've not seen a method for this to be modified using LISP.
The CUIX is a zip file so you can get inside it, and its made up of lots of xml files, if you spent the time to see if the Key combos were in a file then I guess you could edit the file and remake the CUIX.
So copy the cuix rename to zip, make a key change copy again rename to zip, compare somehow the contents of the 2 files looking for differences in the file content.
I was looking at making custom ribbon files by writing the xml code using a simpler txt file as base like the old mnu.
