rectangular array - creating every other row offset?
jetted4
Message 1 of 15
jetted4
I would like to be able to create a rectangular array in which every other row is offset half the distance to the left (see attached jpg).  Is that possible?
Replies (14)
Message 2 of 15
CodeDing
@jetted4 ,
How comfortable are you with blocks?
this seems it could be easily accomplished w/ non-programming methods.
See attached dwg.
--- EDIT ---
I updated the attached DWG to incorporate a second block attempt, which you might prefer.
Best,
~DD
Message 3 of 15
jetted4
Blocks are fine.
I was just hoping their might be some sort of option built in that I wasn't seeing so that I wouldn't have to create a 2nd item in the right spot in order to get the same result.
Thanks  🙂
Message 4 of 15
CodeDing
Hmmm, yeah I cannot think of another method to get that same effect.
Message 5 of 15
stevor
There lisp routines for creating arrays here, and everywhere.
Yours could be 2 arrays, 2 start points.
S
Message 6 of 15
Kent1Cooper
Another thing you can do is to set up two of them with the offset, say, the two closest to the bottom left corner in your image, and then just Array with those two as the selection, using twice the row spacing.  That is simple, but has the possible drawback that you can do only an even number of rows, so if you want an odd number, you'd need to Erase the extra row.
Kent Cooper, AIA
Message 7 of 15
Kent1Cooper
You may find CylinderSphereLine.lsp, available >here<, a starting point.  It's a 3D application, lining the end surfaces and walls of the inside of a cylinder with spheres, but the "floor" part of what it does could be adaptable to your purposes using Circles.
Another option is a Hatch pattern that does what look pretty much like  Circles, though they are really polygons of a large number of sides.  I made several patterns that do that, all called CirclesTriGrid followed by a descriptive suffix, available >here<.  You would want CirclesTriGridOpen.  I think the "circles" it makes [really 24-gons] may be a little closer together than in your image -- the space between is equal to the "diameter" of each.  See the rest of the topic there, and the comments at the top of the file.
Kent Cooper, AIA
Message 8 of 15
jetted4
Thanks to everyone for the ideas.  🙂
It's kind of a common enough sort of need and not overly complicated...wish there were an offset every other row sort of feature option in.
Message 9 of 15
Kent1Cooper
There's a designated place to suggest that to them -- the >Product Feedback< page.
Kent Cooper, AIA
Message 10 of 15
Sea-Haven
It could be done as a row of circles make a list of how many then entity names, copy and create at the diagonal offset, then paste diagonal again sq up. A odd - even style approach looping for as many as required but yeah no direct array.
Message 11 of 15
ParishSouthBdx
for example, if the spacing between the rows is 1", the array the first row of circles on a 2" center to center, then copy those arrays down 1", and then move them over.  but in one fell swoop, not sure
Message 12 of 15
Sea-Haven
Its cold and wet so inside
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rectangular-array-creating-every-other-row-offset/td-p/9667120
; array rows a 1/2 x spacings
; Enter -ve values to change direction.
;By AlanH info@alanh.com.au Aug 2020
(defun c:zigzag ( / ent ss ans hor ver numx numy x )
(setq ent (entsel "\nSelect object to array"))
(setq ss (ssadd))
(ssadd (car ent) ss)
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter spacings " "Horizontal  " 5 4 "100" "Vertical" 5 4 "50" "Num X " 5 4 "3"  "Num Y" 5 4 "3")))
(setq hor (atof (nth 0 ans)))
(setq ver (atof (nth 1 ans)))
(setq numx (atoi (nth 2 ans)))
(setq numy (atoi (nth 3 ans)))
(setq x 1.0)
(repeat (- numx 1)
(command "copy" ent "" (list 0.0 0.0) (list  (* x hor) 0.0) )
(ssadd (entlast) ss)
(setq x (+ x 1))
(setq x 1.0)
(while (< x numy)
(command "copy" ss "" (list 0.0 0.0) (list (* 0.5 (- hor)) (* x ver)))
(setq x (+ x 2))
(setq x 2.0)
(while (< x numy)
(command "copy" ss "" (list 0.0 0.0) (list 0.0 (* ver x)))
(setq x (+ x 2))
(princ)
(c:zigzag)
Message 13 of 15
jetted4
Works great. thanks  🙂
(although it took me a couple of tries before I realized that I needed to load both the imbedded lsp program and the attached one as well)
Message 14 of 15
Sea-Haven
Glad to here it works. The library Multi getvals.lsp can be used in any program. Multi Radio buttons & Multi toggles are available also.
You only need the multi getvals in a support search path location should have all your lisps there. Then can call from menu etc just by name no need for path. Or change the (load "c:\directory\etc\etc\multi getvals") to suit
Message 15 of 15
jetted4
Though it generates the array wonderfully, I did run into a glitch with printing and also with saving the lsp in my contents library that I could use your input on (pls see PM).
Thanks  🙂
