Rectangle with associative hatch LISP
vcostantino
vcostantino
How do I draw rectangle offset 1" outside and make hatch associative.
this is what i have so far:
(defun C:PZ (); Protected Zone
(setq pnt1 (getpoint "Select upper left hand corner for placement of rectangle: "))
(setq pnt2 (getcorner pnt1 "Select lower right hand corner for placement of rectangle: "))
(command "rectangle" pnt1 pnt2)
(setq ent1 (entlast))
(command "-hatch" "P" "ANSI31" "25" "0" "S" ent1"" "")
Kent1Cooper
The BHATCH [rather than HATCH] command has a way to set Associativity.  Here's a quickie that uses it, and does the Offset you mention:
  (setq
    pnt1 (getpoint "Select corner of rectangle: ")
    pnt2 (getcorner pnt1 "Select opposite corner of rectangle: ")
  (command
    "_.rectang" pnt1 pnt2
    "_.offset" 1.0 pnt2 (polar pnt2 (angle pnt1 pnt2) 1) ""
    "_.bhatch" "_advanced" "_associativity" "_yes" "" "_select" "_last" "" ""
Note that it doesn't require specific corners, but you can pick any two opposite corners in either order [in the case of a Rectangle, it's easy to get an Offset command to use a point known to be outside it, regardless of the direction in which it was drawn -- this is not  necessarily easy for just any Polyline].
I'll let you add in further options for pattern name, scale, etc., or you can preset those [and also the associativity, for that matter] with (setvar) functions.
Kent Cooper, AIA
