Rectangle that starts at Center of One End
Does anyone have a lisp that draws a rectangle starting at the midpoint of one end?
Psuedo Code:
Specify starting point
Specify End point
Enter diameter
I realise that Mline would acomplish this however we cannot use multilines in these drawings because some of the rectangle will need a chamfer at one corner.
hmsilva
Hello sbanister,
not quite what you are looking for, but probably a strting point for your code...
These two excellent codes, one from Gian Paolo Cattaneo and the other from Lee Mac have a dynamic approach to a 3 points rectangle.
Hats off to @Lee_Mac and @gpcattaneo
Henrique
Kent1Cooper
Psuedo Code:
Specify End point
Enter diameter
In simplest terms, and untested, try this:
(defun C:RME (/ pt1 pt2 ang wid hwid); = Rectangle by Midpoints of Ends
  (setq
    pt1 (getpoint "\nSpecify midpoint of starting end: ")
    pt2 (getpoint pt1 "\nSpecify midpoint of other end: ")
    ang (angle pt1 pt2
    wid (getdist "\nRectangle width [e.g. pipe diameter]: ")
    hwid (/  wid 2)
  ); setq
  (command "_.pline"
    "_none" (polar pt1 (- ang (/ pi 2)) hwid)
    "_none" (polar pt2 (- ang (/ pi 2)) hwid)
    "_none" (polar pt2 (+ ang (/ pi 2)) hwid)
    "_none" (polar pt1 (+ ang (/ pi 2)) hwid)
    "_close"
  ); command
); defun
It could be made more sophisticated, e.g. to suppress command echoing, remember the width/diameter and offer it as default next time, work in other-than-World coordinate systems, ensure Polyline width of zero, etc.
Kent Cooper, AIA
stevor
Try:
 ; 2 pt rectangLe by midpts, width, 2D: in UCS only  auscadd.com
 (DEFUN Rec_2MP (P Q W / D P1 P2 P3 P4 A B REN PEN ) ; (PP_"p") (P_"q")
  (setq @u"Rec_2MP"  i 0  B (/ pi 2 )  A (angLe P Q )  D (/ W 2)
        P1  (poLar P (- A B ) D )  P2 (poLar P (+ A B ) D )
        P3  (poLar Q (+ A B ) D )  P4 (poLar Q (- A B ) D )
        REN (entlast) ) ; (gr_xdc P 1 1) (gr_xdc Q 1 2)
  (COMMAND "PLINE" "_non" P1 "_non" P2 "_non" P3 "_non" P4 "C")
  ; nyet (command "_.rectangle" "_non" P1 "_non" P3)
 ) ; def
S
Hello again Kent
Apart from the missing closing parenthisis after ang (angle pt1 pt2 it was bang on, well done.
I have tried numerous coding options & was begining to think it wasn't possible
Thank you very much indeed, it's just as needed.
PS my usual mistake is to put too many opening parethesis in 😕
