rebar detaling
I have a big request, from some of gurus :
I have a dynamic blocks with attributes , which represent : the position of rebar quantity diameter and lenght of rebar ,
I have to detail the curved rebars , so if can somebody help me with this ;
Here I found a some lisp , maybe it could be useful:
first one by Alan J. Thompson
(defun c:PLab (/ obj) ;; Label each LWPolyline segment with number and distance ;; Alan J. Thompson, 04.21.10 / 04.23.10 (vl-load-com) (if (and (setq obj (car (entsel "\nSelect LWPolyline: "))) (or (eq "LWPOLYLINE" (cdr (assoc 0 (entget obj)))) (alert "Invalid object!") ) (setq obj (vlax-ename->vla-object obj)) ) ((lambda (n l s / d) (while (nth (1+ (setq n (1+ n))) l) ((lambda (a b / dist) (setq dist (abs (- (setq d (vlax-curve-getDistAtPoint obj a)) (vlax-curve-getDistAtPoint obj b) ) ) ) ((lambda (p) ((lambda (text) (vla-put-AttachmentPoint text 8) (vla-put-InsertionPoint text p) ;; (vla-put-Rotation text (angle a b)) ((lambda (ang) (if (and (> ang (* pi 0.5)) (< ang (* pi 1.5))) (vla-put-rotation text (+ pi ang)) (vla-put-rotation text ang) ) ) (angle a b) ) ) (vla-AddMText s p 0.30 (strcat (itoa (1+ n)) " - " (rtos dist))) ) ) (vlax-3d-point (vlax-curve-getPointAtDist obj (+ (/ dist 2.) d))) ) ) (nth n l) (nth (1+ n) l) ) ) ) -1 (AT:ListGroupByNumber (vlax-get obj 'Coordinates) 2) (if (or (eq acmodelspace (vla-get-activespace (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) ) (eq :vlax-true (vla-get-mspace *AcadDoc*)) ) (vla-get-modelspace *AcadDoc*) (vla-get-paperspace *AcadDoc*) ) ) ) (princ) ) ;;; Group items in list based on specified number ;;; L - List to process ;;; # - Number of items for grouping ;;; Alan J. Thompson, 03.26.10 (defun AT:ListGroupByNumber (L # / n g f) (setq n -1) (while (> (1- (length L)) n) (repeat # (setq g (cons (nth (setq n (1+ n)) L) g))) (setq f (cons (reverse g) f) g nil ) ;_ setq ) ;_ while (reverse f) ) ;_ defun
second one by gilbertomejiac:
(vl-load-com) (defun c:mult-info_po2cell ( / js obj ename n AcDoc Space pr nb lst_id-seg lst_pt lst_length lst_alpha lst_rad id all_path j end_pos id_path fonts_path file_shx nw_obj nw_style dist_start dist_end pt_start pt_end seg_len seg_bulge rad alpha oldim oldlay h_t w_c ename_cell n_row n_column) (princ "\nSelect polylines.") (while (null (setq js (ssget '((0 . "LWPOLYLINE"))))) (princ "\nSelection empty, or is not a available polyline!") ) (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)) Space (if (= 1 (getvar "CVPORT")) (vla-get-PaperSpace AcDoc) (vla-get-ModelSpace AcDoc) ) ) (cond ((null (tblsearch "LAYER" "Table-Polyline")) (vla-add (vla-get-layers AcDoc) "Table-Polyline") ) ) (cond ((null (tblsearch "STYLE" "Text-Cell")) (setq all_path (getenv "ACAD") j 0) (while (setq end_pos (vl-string-position (ascii ";") all_path)) (setq id_path (substr all_path 1 end_pos)) (if (wcmatch (strcase id_path) "*FONTS*") (setq fonts_path (strcat id_path "\\")) ) (setq all_path (substr all_path (+ 2 end_pos))) ) (setq file_shx (getfiled "Select a font file " fonts_path "shx" 8)) (if (not file_shx) (setq file_shx "txt.shx") ) (setq nw_style (vla-add (vla-get-textstyles AcDoc) "Text-Cell")) (mapcar '(lambda (pr val) (vlax-put nw_style pr val) ) (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag) (list file_shx 0.0 (/ (* 15.0 pi) 180) 1.0 0.0) ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) ) ) (setq oldim (getvar "dimzin") oldlay (getvar "clayer") ) (setvar "dimzin" 0) (setvar "clayer" "Table-Polyline") (initget 9) (setq ins_pt_cell (getpoint "\nLeft-Up insert point of table: ")) (initget 6) (setq h_t (getdist ins_pt_cell (strcat "\nHigth text <" (rtos (getvar "textsize")) ">: "))) (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t)) (initget 7) (setq w_c (getdist ins_pt_cell "\nWidth of cells: ")) (setq lst_id-seg '() lst_pt '() lst_length '() lst_alpha '() lst_rad '() nb 0 id 0 ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) ename (vlax-ename->vla-object obj) pr -1 id (1+ id) ) (repeat (fix (vlax-curve-getEndParam ename)) (setq dist_start (vlax-curve-GetDistAtParam ename (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam ename (1+ pr)) pt_start (vlax-curve-GetPointAtParam ename pr) pt_end (vlax-curve-GetPointAtParam ename (1+ pr)) seg_len (- dist_end dist_start) seg_bulge (vla-GetBulge ename pr) rad (if (zerop seg_bulge) 0.0 (/ seg_len (* 4.0 (atan seg_bulge)))) alpha (if (zerop seg_bulge) (angle pt_start pt_end) 0.0) lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa nb)) lst_id-seg) lst_pt (cons pt_start lst_pt) lst_length (cons seg_len lst_length) lst_rad (cons (abs rad) lst_rad) lst_alpha (cons alpha lst_alpha) nb (1+ nb) ) ) (if (eq (vla-get-closed ename) :vlax-false) (setq lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa nb)) lst_id-seg)) (setq lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa (- nb (fix (vlax-curve-getEndParam ename))))) lst_id-seg)) ) (setq lst_pt (cons pt_end lst_pt) lst_length (cons 0.0 lst_length) lst_rad (cons 0.0 lst_rad) lst_alpha (cons 0.0 lst_alpha) nb (1+ nb) ) ) (mapcar '(lambda (p tx) (setq nw_obj (vla-addMtext Space (vlax-3d-point p) 0.0 tx ) ) (mapcar '(lambda (pr val) (vlax-put nw_obj pr val) ) (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation) (list 5 h_t 5 p "Text-Cell" "Table-Polyline" 0.0) ) ) lst_pt lst_id-seg ) (vla-addTable Space (vlax-3d-point ins_pt_cell) (+ 2 nb) 6 (+ h_t (* h_t 0.25)) w_c) (setq ename_cell (vlax-ename->vla-object (entlast)) n_row (1+ nb) n_column -1) (vla-SetCellValue ename_cell 0 0 (vlax-make-variant (strcat "Summary of " (itoa (sslength js)) " LWPOLYLINES") 8 ) ) (vla-SetCellTextStyle ename_cell 0 0 "Text-Cell") (vla-SetCellTextHeight ename_cell 0 0 (vlax-make-variant h_t 5)) (vla-SetCellAlignment ename_cell 0 0 5) (foreach n (mapcar'list (append lst_id-seg '("N°")) (append (mapcar 'rtos (mapcar 'car lst_pt)) '("Coordinates X")) (append (mapcar 'rtos (mapcar 'cadr lst_pt)) '("Coordinates Y")) (append (mapcar 'rtos lst_length) '("Lengths")) (append (mapcar 'angtos lst_alpha) '("Directions")) (append (mapcar 'rtos lst_rad) '("Radius")) ) (mapcar '(lambda (el) (vla-SetCellValue ename_cell n_row (setq n_column (1+ n_column)) (if (or (eq (rtos 0.0) el) (eq (angtos 0.0) el)) (vlax-make-variant "_" 8) (vlax-make-variant el 8)) ) (vla-SetCellTextStyle ename_cell n_row n_column "Text-Cell") (vla-SetCellTextHeight ename_cell n_row n_column (vlax-make-variant h_t 5)) (if (eq n_row 1) (vla-SetCellAlignment ename_cell n_row n_column 5) (vla-SetCellAlignment ename_cell n_row n_column 6) ) ) n ) (setq n_row (1- n_row) n_column -1) ) (setvar "dimzin" oldim) (setvar "clayer" oldlay) (prin1) )
