Rebar Detailing
Rebar Detailing
Rebar Detailing
Hi All,
In RebarCAD once you erase the bar label even though as set, it will be included in total used bar count.
Is there any comment to erase those labels permanently other than “CADS_RC_RCTOACAD”?
Please advise.
rapidcad
Is it possible that you are referring to Revit Structure, Advance Steel, or AutoCAD Structural Detailing with this question? This is the forum for custom written Autolisp and variants of it for use within AutoCAD. You might find an answer in the following forums:
https://forums.autodesk.com/t5/autocad-structural-detailing/bd-p/346
https://forums.autodesk.com/t5/advance-steel-forum/bd-p/2056
https://forums.autodesk.com/t5/revit-structure-forum/bd-p/153
I've been out of the structural loop for 7 years now so I can't help you with your question.
Hope this helps,
ADN CAD Developer/Operator
No Mr.Ronald A.Powell...Rebar CAD not related to Revit Structure, Advance Steel, or AutoCAD Structural Detailing. It just supporting software for Auto CAD.it's used for detailing the REBAR and preparing for BBS (Bar Bending Schedule). Still now it has been mostly used for US & UK projects. Any how thanks for your comment's.
