Read and Write Custom of a Block using autolisp
22352065NTPYQ
22352065NTPYQ
What is the autolisp syntax to read and write Custom of a block . It can be seen by selecting the object and executing command "PR (PROPERTIES)"  through UI.
I am using Autocad electrical 2025.
Sea-Haven
Electrical may have blocks that are proxy objects re custom objects, may need Electrical to get at those objects, similar problem with CIV3D.
Can you post a sample dwg.
komondormrex
@22352065NTPYQ
normally the following expressions will work to get/set dynamic block properties
(getpropertyvalue (car (entsel)) "AcDbDynBlockPropertyDistance1")
(setpropertyvalue (car (entsel)) "AcDbDynBlockPropertyDistance1" 5)
22352065NTPYQ
Thanks a lot
