read a line from csv from index 2 to the end of line
ss6153
ss6153
Hello Reader
my question is in different parts so i am listing them out:
1) I have defined a function this way
(defun test ( str1 x y text1 text2)        ---(a)
and then using this to insert
(command "_insert" str1 insertpt1 "" "" "" text1 text2)                                        ---(b)
I want to pass a list instead of text1,text2, where 'text' is a list of strings
So if i am not wrong, I will modify (a) like this
How should I modify (b) ?
2) I am reading data from a csv file using Lee Mac's readcsv function
After (setq data (LM:readcsv file)), I am accessing each line of the csv like this:
(foreach line data       ;; etc etc        ---(c)
The csv looks something like this:
"A",34,35,"B","C","D"
"AA",42,46
"AAA",29,54,"BB","CC","DD","EE","FF"
What I am aiming for is:
for every element in 'line' (reference to (c)) if the index of element is greater than 2 then append it to a list, say 'textlist'   [catering to corner case that list is empty]
How should go about doing that ?
3) Now I should be able to call the function test like this:
(test name (read p1) (read p2) textlist)                                      ; ignore name, p1,p2. already read from csv
Please help me...
ВeekeeCZ
Ad 1 look into help for car, cadr, last functions.
Ad 2 use another Lee's function then see the help for the nth and append functions
http://www.lee-mac.com/stringtolist.html
Sea-Haven
Like  it is sometimes easier to use Nth for long lists, (nth x lst) you just need to know that a nth starts at 0 not 1, (length lst) will tell you how many items are in a list so (> (length lst) 2) do something. You can use something like
(setq x 2)
(repeat (- (length lst) 2)
(setq lst2 (cons (nth x lst) lst2)) ; or make a string here
(setq x (1+ x))
