Reactors for Publish when selecting several layout tabs
I have a reactor for "PUBLISH", it works fine when the command is typed-in using the keyboard.
However, the reactor does not work when selecting several layout tabs and use the mouse right-click to select the "Publish Selected Layouts..." from the pop-up menu.
I also tried a reactor that is triggered by the right-click of the mouse; that doesn't seem to work either, when used as above.
Is there a way to write a reactor in Vlisp or VBA to work in this particular case, or is another language required for this purpose?
Thank you in advance
maratovich
What does REACTOR mean? Do you have a lisp or a program?
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Moshe-A
@Anonymous  hi,
which reactor?  post your code
