Reactor to reinsert block after PURGE
C.Utzinger
C.Utzinger
HI
Why does AutoCAD refuse the command "_.insert"???
(defun c:<Test1 ( / )
 (vl-load-com)
(defun VTF2 (CALL CALLBACK)
   (if (= (strcase (car CALLBACK)) "PURGE")
       (if (not (tblsearch "block" "el_1"))
           (progn (command "_.insert" "el_1")(command)))
(setq VTFRXN2 (vlr-editor-reactor nil '((:VLR-commandEnded . VTF2))))
Regards
_gile
You cannot use the command function within a reactor callback function.
You can set "unpurgeable" a block definition (or any other object) using a hard pointer.
Some routines from my tool box:
;; gc:GetExtDict (gile)
;; Gets the object extension dictionary (or nil)
;; Argument : obj (ENAME)
(defun gc:GetExtDict (obj)
  (cdadr (member '(102 . "{ACAD_XDICTIONARY") (entget obj)))
;; gc:GetOrCreateExtDict (gile)
;; The dictionary is created if not already exists
(defun gc:GetOrCreateExtDict (ent / dict)
  (cond
    ((cdadr (member '(102 . "{ACAD_XDICTIONARY") (entget ent))))
    ((setq dict	(entmakex
		  '((0 . "DICTIONARY") (100 . "AcDbDictionary"))
     (entmod
       (vl-list*
         (assoc -1 elst)
         (assoc 0 elst)
         (assoc 5 elst)
         (cons 102 "{ACAD_XDICTIONARY")
         (cons 360 dict)
         (cons 102 "}")
         (vl-remove-if (function (lambda (x) (member (car x) '(-1 0 5)))) elst)
     dict
;; gc:SetXrecData  (gile)
;; Returns the ENAME of the xrecord which data are set to
;; Arguments
;; dict : ENAME of the parent dictionary
;; key  : name of the xrecord
;; data : dotted pair list containg data
(defun gc:SetXrecData (dict key data / xrec)
  (if (snvalid key)
    (progn
      (and (setq xrec (dictsearch dict key))
           (entdel (cdr (assoc -1 xrec)))
      (dictadd
        dict
        key
        (entmakex
          (append
            (list '(0 . "XRECORD")
                  '(100 . "AcDbXrecord")
            data
;; gc:GetXrecData  (gile)
;; Gets the data of the xreord (dooted pair list)
;; Arguments
(defun gc:GetXrecData (dict key / xrec)
  (if (and
        (= (cdr (assoc 0 xrec)) "XRECORD")
    (cdr (member (assoc 280 xrec) xrec))
;; gc:SetUnPurgeable  (gile)
;; Sets unpurgeable the table record (AcDbSymbolTableRecord)
;; Returns T if succeeded; nil otherwise
;; Arguments
;; table : the table name
;; name  : the record name
(defun gc:SetUnPurgeable (table name / symbol xdict)
  (and
    (setq symbol (tblobjname table name))
    (setq xdict (gc:GetOrCreateExtDict
                  (cdr (assoc -1 (entget (cdr (assoc 330 (entget symbol))))))
    (gc:SetXrecData
      xdict
      "UnPurge"
      (cons (cons 340 symbol) (gc:GetXrecData xdict "UnPurge"))
;; gc:ResetPurgeable  (gile)
;; Reset purgeable the table record (AcDbSymbolTableRecord)
;; Arguments
(defun gc:ResetPurgeable (table name / symbol xdict)
  (and
    (setq data (gc:GetXrecData xdict "UnPurge"))
    (member (cons 340 symbol) data)
    (or
      (and (= 1 (length data)) (dictremove xdict "UnPurge"))
      (gc:SetXrecData
        xdict
        "UnPurge"
        (vl-remove (cons 340 symbol) data)
;; gc:ResetAllPurgeable  (gile)
;; Reset purgeable all records previously set as unpurgeable
(defun gc:ResetAllPurgeable (/ name symbol xdict)
  (foreach table '("LAYER" "LTYPE" "VIEW" "STYLE" "BLOCK" "UCS" "APPID" "DIMSTYLE" "VPORT")
    (and
      (setq name (cdr (assoc 2 (tblnext table T))))
      (setq xdict (gc:GetExtDict (cdr (assoc 330 (entget symbol)))))
Gilles Chanteau
GileCAD
GitHub
C.Utzinger
OK!
I got T when I use it like this:
But I still can purge the block. Is that correct?
(gc:SetUnPurgeable "block" "el_1")
Thank you!
_gile
Oopss!...
My mistake, I pasted the wrong code, try this one.
  (cond
    ((cdadr (member '(102 . "{ACAD_XDICTIONARY") (setq elst (entget ent)))))
     (entmod
       (vl-list*
         (assoc -1 elst)
         (assoc 0 elst)
         (assoc 5 elst)
         (cons 360 dict)
         (cons 102 "}")
     dict
;; Arguments
  (if (snvalid key)
    (progn
      (dictadd
        dict
        key
        (entmakex
          (append
            data
;; Arguments
  (if (and
;; Arguments
(defun gc:SetUnPurgeable (table name / symbol record xdict)
  (and
    (setq record (cdr (assoc 330 (entget symbol))))
                  (cdr (assoc -1 (entget (cdr (assoc 330 (entget record))))))
    (gc:SetXrecData
      xdict
      "UnPurge"
      (cons (cons 340 record) (gc:GetXrecData xdict "UnPurge"))
;; Arguments
(defun gc:ResetPurgeable (table name / symbol record xdict)
  (and
    (setq xdict (gc:GetOrCreateExtDict (cdr (assoc 330 (entget record)))))
    (member (cons 340 record) data)
    (or
      (gc:SetXrecData
        xdict
        "UnPurge"
(defun gc:ResetAllPurgeable (/ name record xdict)
    (and
      (setq record (cdr (assoc 330 (entget (tblobjname table name)))))
      (setq xdict (gc:GetExtDict (cdr (assoc 330 (entget record)))))
Gilles Chanteau
GileCAD
GitHub
C.Utzinger
Thank you very much!
It works prefect!
Best regards
C.Utzinger
HI
I have a Little problem with the gc:ResetPurgeable function. It does not work 😉
The gc:ResetAllPurgeable works perfect.
Can give me another Hand please? Thank you!
Kind regards
_gile
This one should work.
  (cond
     (entmod
       (vl-list*
         (assoc -1 elst)
         (assoc 0 elst)
         (assoc 5 elst)
         (cons 360 dict)
         (cons 102 "}")
     dict
;; Arguments
  (if (snvalid key)
    (progn
      (dictadd
        dict
        key
        (entmakex
          (append
            data
;; Arguments
  (if (and
;; Arguments
  (and
    (gc:SetXrecData
      xdict
      "UnPurge"
;; Arguments
  (and
    (or
      (gc:SetXrecData
        xdict
        "UnPurge"
        (vl-remove (cons 340 record) data)
    (and
Gilles Chanteau
GileCAD
GitHub
