Reactor for open and close dwg
DGRL
Advisor Advisor
DGRL
Dear forum members,
I have an reactor that will fire an lsp when user presses SAVE or QSAVE
I googles unsuccessfully my ass off to find a way to change this one into endopen en close of dwg
Instead of running up the lsp when a user presses save I want it to run when an dwg is opened or when it will close
This is the code now
(vlr-command-reactor
  nil
  '((:vlr-commandEnded . endCommand))
(defun endCommand (calling-reactor endcommandInfo / thecommandend)
  (setq thecommandend (nth 0 endcommandInfo))
  (cond
    ((= thecommandend "QSAVE") (qs:backup))
    ((= thecommandend "SAVE") (qs:backup))
Best regards
If this was of any help please kudo and/or Accept as Solution
Kind Regards
DannyNL
In that case you cannot use a command reactor as this will only react to commands and not specific events.
To create a reactor with your specifications you should probably use a vlr-dwg-reactor,
See: http://help.autodesk.com/view/ACD/2018/ENU/?guid=GUID-82B7F0D1-02AD-4463-A8A3-BF87EFCC83A4
Ranjit_Singh
You can setup reactor to process certain code when a drawing is opened. However, this will execute commands in the original document and not in the newly opened file. To take action on the new opened document use the S::STARTUP function.
For document close, you are using commandended reactor. There is nothing left to do after the commandended event for a dwg close. AutoCAD will simply release lock on file. You may want to use commandwillstart event and do whatever processes you need. If the command is cancelled then detect that with a commandcancelled event and undo all of those processes (or not depending on your logic).
john.uhden
vlr-dwg-reactor is definitely correct.
You can use (strcase (getvar "cmdnames")) to find out what command triggered it.
John F. Uhden
