Re: Copy / Paste / Rotate several time without redefine object or base point.
m.lharidon
Message 1 of 8
m.lharidon
In the "Copy block x time between 2 points (with orientation) (CM2P adaptation)" Topic I discover I can use this fontion (to have the blocks I use alway align with :
 (setq blk_ent (entget (entlast)))
      (entmod (subst (cons 50 rad)(assoc 50 blk_ent)blk_ent))
      (setq e (entlast))
I tried to integrate it In the CBPRM Lisp but I have an error "bad DXF group". Here is the lisp:
(defun C:CBPRMB (/ e p); = CopyBase and Paste/Rotate Multiple
  (if
    (and
      (setq e (car (entsel "\Object to Paste/Rotate Multiple times: ")))
      (setq p (cdr (assoc 10 (entget e))))
    ); and
    (progn ; then
      (command "_.copybase" p e "")
      (setq e (entlast))
      (while (setq p (getpoint "\nPaste base point or <exit>: "))
        (command
          "_.pasteclip" p
          "_.rotate" "_last" "" p pause
        ); command
      ); while
    ); progn
  ); if
  (princ)
Can you help me for that?
Thanks.
ML
Replies (7)
Message 2 of 8
ВeekeeCZ
I don't really understand how you imagine the workflow, but this issue with your code is that you never set the rad variable.
Elaborate your workflow a bit, where to get the angle from, if you need more help.
      (setq e (entlast))
  (if
    (and
    ); and
    (progn ; then
      (setq e (entlast))
        (command
          "_.pasteclip" p
        ); command
      ); while
    ); progn
  ); if
  (princ)
Thanks.
ML
Message 3 of 8
dbhunia
Try like this.......
  (if
    (and
    ); and
    (progn ; then
      ;(setq blk_ent (entget (entlast)))
      ;(entmod (subst (cons 50 rad)(assoc 50 blk_ent)blk_ent))
      ;(setq e (entlast))
        (command
          "_.pasteclip" p
        ); command
      ); while
    ); progn
  ); if
  (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 4 of 8
m.lharidon
Unfortunatly, the fonction you corrected stays the same at it was before. When I define a block with rotation at x° it keeps x+90°. What i looked for it to always concider the selected block as 0°. then when i copy i give the orientation from 0. (first click past the block, second click orient it where i click.
(attached an exemple to make it clearer).
Thanks for the help.
Message 5 of 8
dbhunia
(defun C:CBPRMB (/ e p blk_ent); = CopyBase and Paste/Rotate Multiple
  (if
    (and
    ); and
    (progn ; then
        (command "_.pasteclip" p)
        (entmod (subst (cons 50 0.0)(assoc 50 blk_ent)blk_ent))
        (command "_.rotate" "_last" "" p pause
        ); command
      ); while
    ); progn
  ); if
  (princ)
Debashis Bhunia
Message 6 of 8
ВeekeeCZ
Here is re-written version of Kent Cooper's idea
- works in UCS
- allows pre-selection
- gives you a previous when placing the block
- has to be finished by ESC pressing (guess the preview worth this little inconvenience)
(defun C:CBPRMB (/ *error* e p r); = CopyBase and Paste/Rotate Multiple
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " errmsg)))
    (princ)
    );end error
  (if (setq e (if (ssget "_I")
                (ssname (ssget) 0)
                (car (entsel "\Object to Paste/Rotate Multiple times: "))))
    (progn ; then
      (setq r (getpropertyvalue e "Rotation"))
      (setpropertyvalue e "Rotation" (angle '(0 0 0) (getvar 'UCSXDIR)))
      (setpropertyvalue e "Rotation" r)
      (while T
        (command "_.pasteclip" pause
                 "_.rotate" "_last" "" "@" pause))))
  (princ)
Message 7 of 8
m.lharidon
Thanks a lot tor the feedback
Message 8 of 8
m.lharidon
Thanks a lot, this is perfect!!
